Results 1 to 8 of 8
07-27-2018, 11:16 AM #1
Setting Up 2000 Outback DD for Wakeboarding
Hello All!
New to the forum, and Moomba boats. Moved up from a 17' Maxum Runabout, so this was a huge upgrade for me. After learning to get up and get comfortable at speed getting pulled from a ski loop on the back of that, we decided it was time to find a boat with a tower, and stumbled across a killer deal on this 2000 Outback, 5.7 Indmar and a Monster MT2 Tower.
After a few weekends behind it, I'd like to look into making the wake a little cleaner and with some more shape to start trying jumps and things. We don't currently have any ballast in the boat but would look into setups that work best for beginner/intermediate boarders.
Untitled by Skee907, on Flickr
This is the wake I get with two people, light gear, and a full tank of gas. Between 18-20mph, with the standard teak wood platform on the rear.
How it was loaded at the time of the picture.
Any tips and opinions are appreciated!- 1999 Moomba Outback LS/SK - 5.7 Indmar, Monster MT2 Tower, Kenwood Audio, Pyle Wake Tower Speakers
07-28-2018, 01:55 AM #2Junior Member
- Jul 2016
- Boise, ID
- 11
I have a similar boat. The quickest change is to adjust your rope length to the best part of the wake. The next thing would be to remove your back seat and add some ballast bag(s) in that area. There are some others in the forum that have added ballast to the sides of the engine and even in the bow.
'99 Outback DD - sold
07-30-2018, 09:18 AM #3
07-30-2018, 02:52 PM #4
In my 2000 LS, I ran a 750 IBS under the front nose cushions (manually filled from pump over the side) and a 800# bag in the rear locker, however, I notice yours doesn't have the rear ski locker... that same bag might fit under the rear seat?
2008 OBV
325 EFI with closed cooling
Gravity III with 750's in the rear, 400 stock floor, 750 IBS
Servo valve ballast upgrade
Wetsounds Rev10
JL Amps, WS420BT
2000 Outback LS <-- Sold!!!
310 Carb Direct Drive
800# Rear Locker
750# IBS (should have kept this for the OBV)
Dual Batteries with 2 Bank Charger System
Kenwood Head with Remotes
Too many hours restoring exterior from prior negligence to count!
07-30-2018, 02:54 PM #5- 1999 Moomba Outback LS/SK - 5.7 Indmar, Monster MT2 Tower, Kenwood Audio, Pyle Wake Tower Speakers
07-30-2018, 03:00 PM #6
The large bag might be a bit much, BUT if you routinely go light on human ballast, the extra weight won't hurt. These 2 are specifically meant to go in the rear with the seat removed.
https://www.wakemakers.com/wakeboard...-seat-sac.html
https://www.wakemakers.com/fly-high-fat-seat.html
I had 800# in the extreme rear and it would put the swim deck 4-6" underwater...2008 OBV
Wetsounds Rev10
JL Amps, WS420BT
800# Rear Locker
07-30-2018, 03:16 PM #7
I use two 500# sacs on each side of the motor and a 400# in the walk through. watch that you don't swamp it. easy to do
Web.
1997 Outback and stopped looking
07-30-2018, 03:57 PM #8
Here is a snapshot from a video from this week. 400lbs of buddies on the back bench, ~150 driver, 55lb dog, and our gear. 18-20mph. It definitely cleaned up more. Need to find some bags to test before I start buying them lol
Sent from my iPhone using Tapatalk- 1999 Moomba Outback LS/SK - 5.7 Indmar, Monster MT2 Tower, Kenwood Audio, Pyle Wake Tower Speakers
