Results 1 to 10 of 16
Thread: Rear Anchor
07-24-2018, 09:31 AM #1
Rear Anchor
Just wondering what everyone uses for a rear anchor when they are parked at the sand bar so the boat doesn't swing around on them.
Thanks2004 Mobius LS
07-24-2018, 09:43 AM #2
A shore spike by slide anchor.
Slide Anchor On and Off Shore Spike - Small https://www.amazon.com/dp/B003E1QG78..._7YYvBb1DD3Q2G
Sent from my iPhone using TapatalkDavid
07-24-2018, 10:13 AM #3
07-24-2018, 10:20 AM #4
$60, crap. I just use a dog tie down.
https://www.walmart.com/ip/Securelin...Stake/46862695
$4 and never had an issue.2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
07-24-2018, 10:28 AM #5Junior Member
- Jul 2018
- 1
SuperStick Shallow Water Anchor Pin, 3/4" x 7'
Sold by: Amazon.com Services, Inc.
$64.99
AIRHEAD AHDL-4 Bungee Dockline 4 Feet
$10.99
07-24-2018, 10:54 AM #62018 Supra SL550 with 850lbs of lead wake
2017 Supra SA400 (Sold)
2021 GMC Denali 2500
Soulcraft Vodoo
Soulcraft Jordi Pro
Soulcraft Super AV
Phase Five Matrix
07-24-2018, 11:15 AM #7
07-24-2018, 12:59 PM #8
Rear Anchor
On our lake everyone uses pvc pipe anchors made from 2-1/4” PVC made with a “T” connector on top and then a couple of 6” legs out of the T. The main leg is 4’ long with a 45° slash cut into the bottom to make it easier to start into the sand. You just twist and push it down a couple of feet to set it, and we use one on either side of the boat, in a diagonal fashion. I.e. port front and starboard rear. Works perfect and cost about $10 to make.
No need for the augers, they are completely unnecessary IMO. So easy anybody can make them. Just use the proper pvc primer and glue so they stay together.
Like this but without the augers.
Sent from my iPad using TapatalkLast edited by Stazi; 07-24-2018 at 01:03 PM.
2017 Moomba Craz
07-24-2018, 01:16 PM #9Senior Member
- Jan 2018
- Lexington, KY
- 369
Sandbar, what's that?!
Kidding, obviously I know what a sandbar is, but it's not a thing around here. Our big lakes are all shale, so rocky shoreline. no beaching. no sandbars. but awesomely clear water!2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
07-24-2018, 01:39 PM #10
Each area requires unique methods. I use a dog spike that doesn't always work because of rocks underneath the sand. I will use rocks which are usually nicely piled by others from previous tie ups. When I do dive rescue the rear anchor is a much smaller anchor and is as simple as a coffee can with concrete. A mushroom anchor to keep the back end from swinging around is all you should need.
1998 Mobius
310 HP PCM
SOLD
