Results 1 to 3 of 3
07-18-2018, 03:13 PM #1Junior Member
- May 2011
- 7
High engine temp during sharp turns
I have a 2010 lsv and bought it new. This season I get a high engine temperature when I turn. Sharper the turn higher the temp. Once I stop it goes back to normal. Normal is 160f and +200f high when turning. I changer the water pump impeller, but no change. I find it interesting it changed so quickly. Anyone have had the same problem or suggestions?
07-18-2018, 05:09 PM #2
Maybe when you're turning sharp you're disrupting the flow of water into the raw water intake...
Suggestion? Don't turn so sharp obviously! LOLOLOL2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
07-18-2018, 05:31 PM #3
Both right and left turns? Check your scupper. Every time you turn or intermittant? Ive got nothing.....
99 Outback LS. Sold
