Results 1 to 3 of 3
07-15-2018, 11:34 AM #1Junior Member
- Sep 2017
- Dousman, Wi
- 7
water trapped between floor and hull
I have a 2001 outback ls open bow. when skiing or wakeboarding all is good. If I pull tubers and am doing s turns back and forth, water starts showing up at the observers seat. Seems to trapped in the floor,hull, stringer system. Is this a know problem and what steps should I do to correct it ?
Jim
07-15-2018, 08:51 PM #2Senior Member
- May 2016
- West Milwaukee, WI
- 283
Yes, this is a known issue. There's a thread around here with some details about cutting a circular hole in the bottom of the ski locker, vacuuming out the water, then installing an access cover over the hole.
Sent from my OnePlus 5 using Tapatalk2004 Mobius LS - hooked on footin'
Former tow: 1986 Chaparral 178 XL, 90hp Merc
First tow: 197x Glasspar Citation, 135hp Merc
07-16-2018, 08:23 AM #3Junior Member
- Sep 2017
- Dousman, Wi
- 7
Thanks, Jim
