Results 1 to 10 of 10
07-11-2018, 12:18 PM #1
Issue connecting Bluetooth with phone
Is there a trick to getting the phone linked with Bluetooth. It seems as bad as ford SYNC. My phone (or any phone on the boat) does not pick up the Bluetooth to connect.
Thanks,2018 Max - Wetsounds - Wake Makers upgrade
07-11-2018, 01:32 PM #2Senior Member
- Jan 2018
- Lexington, KY
- 369
Maybe a dumb question, but did you make the boat "discoverable"? Discoverable turns off either after an amount o time or with a key cycle too...
It's at the bottom of the main Bluetooth menu.2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
07-11-2018, 06:45 PM #3
[QUOTE=korey;328452]Maybe a dumb question, but did you make the boat "discoverable"? Discoverable turns off either after an amount o time or with a key cycle too...
It's at the bottom of the main Bluetooth menu.[/QU
Not a dumb question for me lol, I do not remember seeing a make "discoverable" selection. I will look for that. Thank you2018 Max - Wetsounds - Wake Makers upgrade
07-12-2018, 09:00 AM #4Senior Member
- Jan 2018
- Lexington, KY
- 369
I happened to have a PDF of the manual on my desktop!2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
07-12-2018, 11:33 AM #5
That's interesting it says its only discoverable for 2 minutes, ive never once had to select make discoverable, it has always paired a new phone or my re paired my phone without doing that.
2017 Craz surf auto wake
1140 # rears wet sounds
07-12-2018, 12:07 PM #6Senior Member
- Jan 2018
- Lexington, KY
- 369
Hmm, I've always had to turn discoverable on to connect a new phone, but any phone has been paired before links no problem.
07-11-2018, 06:00 PM #7
I gave up on the Bluetooth so tired of it and just run the cable to the USB port and put my phone on it
Sent from my iPhone using Tapatalk2015 Mojo
2005 Yamaha at-230 sold
2012 Ram 2500 tow rig
07-11-2018, 06:28 PM #8
mine seems to work flawlessly, use it all the time, synced a new phone on Saturday in less than a minute, just changed the deck to Bluetooth audio, went into Bluetooth settings on phone, refreshed, or scan for new device, the boat popped up and presto.
07-12-2018, 01:44 PM #9
My fusion head unit died and I bought a new one. I’ve been having a lot of issues with BT since. 50/50 it pairs and I get Audio but no metadata & cant change songs on head unit or transom remote. Another issue is pairing to android phones. Even when discoverable it won’t recognize. Luckily I have an iPhone but still a PIA
Sent from my iPhone using Tapatalk2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
