Results 1 to 5 of 5
Thread: Raw water pump valve location??
07-05-2018, 11:41 PM #1
Sorry for the dumb question but this is my first summer with my 15 Mondo after a full winterization. Tag says to make sure the raw water pump valve is open. Anybody know where it is on the Raptor? Also I'm assuming the ballast pump valves are under the removable back panels in the lockers. Any other tips for getting it water ready are welcome. Late start this year, can't wait to get out!!!
Pat'19 Moomba Max
07-06-2018, 05:36 AM #2Member
- Sep 2017
- Hanover, VA
- 91
I have a 2018 Mojo and all the valves are on the fittings that go through the hull bottom. If yours is similar you can access them through the access cover for the V-drive.
07-06-2018, 12:06 PM #3
07-06-2018, 05:22 PM #4
Thanks guys. I found the three ballast valves under the tranny cover, couldn't find the raw water intake. Might have to try tracing the intake hose on the impeller. The place that winterized it said some will have a raw water valve, some will not. I'm guessing if the hose goes from the impeller straight to the hull, I should be OK.
'19 Moomba Max
07-07-2018, 09:37 PM #5
