Results 1 to 9 of 9
10-20-2006, 04:44 AM #1Member
- Oct 2006
- Hong Kong
- 61
Tachometer doesn't work correctly on 2004 LSV
I have a 2004 LSV lately my Tachometer does not read correctly it stays at around 800~1000 rpm or so all the time, and once a while it will flip to max or normal. I have went to a shop they said i need to order a new Tachometer and sensor is that correct? and where can I oder these things. And other problem is that the LSV is not in USA anymore i have shipped it overseas. Please help guys
10-21-2006, 10:55 PM #2Senior Member
- Jul 2003
- 340
Before you order a new one check the wiring and make sure you don't have any loose wires that could be causing the problem.
10-23-2006, 09:54 AM #3Brian Raymond Guest
On the backside of the tach, there are 8 mini switches. These are used to tell the tach what type of motor it is running (4,6,8, cyl). Be sure these switches are in order. For the 8 cyl. application, The #2 switch should be in the up position, and all other switches in the down position. Also check and make sure the wire connections are tight while your back there. Verify you have a good connection at the engine harness. If all is good, a tach replacement may be in your future. Contact a dealer, and get a (part #104699) tach. Hope this helps, keep us posted. Brian Raymond
10-24-2006, 03:39 PM #4Member
- Oct 2006
- Hong Kong
- 61
Originally Posted by Brian Raymond
10-25-2006, 09:53 PM #5Brian Raymond Guest
There is no sensor on the tach, it receives its signal from the coil. I would venture to say, that, if the connections are clean and tight, the switches in the proper positions, you may need a new tach. If it was a coil breaking down, or giving a varied signal, you would definately hear and feel it with poor motor performance. Brian Raymond
10-28-2006, 11:51 AM #6Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Lots of stuff I never touch gets moved, lost, or broken - I'd check the switches.
11-15-2006, 03:08 AM #7Member
- Oct 2006
- Hong Kong
- 61
I think i have to order a new tach. and how do i order the tach or more like where? and whats the price range be?
and i want to order replacement navigation light thats on top of the tower since it snapped, and the front navigation light fell in the water so i need that too.
where and how do i order these parts.
11-28-2006, 01:45 AM #8Member
- Oct 2006
- Hong Kong
- 61
11-28-2006, 01:14 PM #9Senior Member
- Oct 2005
- Central FL
- 791
Brian gave you the part number. Contact a dealer in your area and tell them you need one. They are not terribly expensive.
-J
HELP ME.. <would this work on my boat>
By JoeTechie in forum General ChatReplies: 8Last Post: 02-02-2007, 05:51 PM -
it didn't work
By Zihuatanejo in forum Pride & JoyReplies: 1Last Post: 12-14-2006, 08:47 PM -
Tachometer
By Lwind in forum General ChatReplies: 0Last Post: 01-31-2004, 12:35 AM -
Tachometer Problems
By wdf in forum Service & RepairReplies: 6Last Post: 08-11-2003, 11:21 AM -
Want a Mooba (again)...didn't seem to work....
By moombaschleg in forum General ChatReplies: 2Last Post: 11-05-2002, 07:33 PM
