Results 11 to 19 of 19
07-03-2018, 03:25 PM #11I don't mind paying for the better fuel,
Most all newer high compression engines are going to the cooler burning octanes.
Ethanol blended has a lower BTU and MPG then pure gas of the same octane. Thats why many notice a difference in fuel mileage between pure and E-10 gas.
07-03-2018, 04:28 PM #12Member
- Aug 2010
- 53
I’ve been told by two separate dealers selling indmar powered products that 87 is fine to run in the 400.
86 Supra Sunsport
16 MB Sports F21
07-03-2018, 04:36 PM #13
What octane fuel is everyone running?
As long as the ECM has high and low octane timing tables and utilizes Knock sensors to put it into the low octane timing table, I would agree.
Lower timing means reduced power but would be safe if 87 was all that was available.
E85 is badass in forced induction applications, it’s typically 100-105 octane. It’s truly race gas.
I have a 2010 CTSV with an LSA 6.2, E85 is amazing in supercharged engines.
But you need enough fuel pump to run it, flex fuel sensors and hybrid tuning for gas and E85 simply because E85 availability is still so limited. E50 seems to be the biggest bang for the buck (mix of 93 and E85 until flex sensor reads E50ish)
All said thought, E85 would suck for boats as it would draw so much moisture.
Sent from my iPhone using TapatalkLast edited by larry_arizona; 07-03-2018 at 04:45 PM.
2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
07-03-2018, 05:01 PM #14
All 89 gas is just a 50/50 87-93 mix done at the pump.
Worst case scenario just throw half 91 or 93 in there until you can get 89Overkill is underrated
2006 Supra 24SSV Gravity Games- traded but never forgotten
2017 Supra SA 400
07-04-2018, 09:17 PM #15Member
- Aug 2016
- 98
i run 87 in my 08 lsv, everything newerish has a knock sensor so whatever you run it will retard timing if knock is detected
07-04-2018, 10:19 PM #16Senior Member
- May 2016
- West Milwaukee, WI
- 283
We use 89 as that's the lowest octane we can get without ethanol. Our local 87 has 10% ethanol.
Sent from my OnePlus 5 using Tapatalk2004 Mobius LS - hooked on footin'
Former tow: 1986 Chaparral 178 XL, 90hp Merc
First tow: 197x Glasspar Citation, 135hp Merc
07-05-2018, 03:55 PM #17Member
- May 2018
- Little Rock, AR
- 35
I run E10 87 octane all summer and will put the blue Stabil for ethanol every second or third time I top off gas. I rarely let it go below 1/2 tank. When the boating season is winding down, I will run whatever octane ethanol free gas I can get. Finding any ethanol free is a small challenge and some stations only carry 87 others 93.
The longer your ethanol based fuel sits around the more likely you will get phase separation and H20 in the gas so do not worry about it when I am filling the gas up every week or 2.'14 Mojo 2.5
07-05-2018, 04:22 PM #18
93 all day.
2020 SA ?,2019 SE550
2018 G23 sold
2017 SE450,2016 SA400 Sold
2015 MB B52 23,2012 MB F21 Sold
2014 Axis A22, 2010 Axis A22 Sold
2018 Ram 2500
07-05-2018, 04:39 PM #19
I run 91 all the time.
Sent from my iPhone using Tapatalk2016 Craz
2007 LSV - Sold
2003 Outback - Sold
