Results 1 to 10 of 13
Thread: 2002 Outback LS wont turn over
06-30-2018, 02:06 PM #1
1.Battery is good, everything else runs
2. Amp don't even draw down when cranking
3. Was able to get started it started with some luck by jiggling wires coming off distributor. Can't pinpoint which one did it.
Open to all suggestions, it 98 and humid and I need to get everyone on the water!
Sent from my SM-G950U using TapatalkFins to the left.
2002 Outback LS
06-30-2018, 03:54 PM #2
Knocked the power wire off the fuel pump?
Sent from my SM-G950U using Tapatalk-Mark
"Hey you only live once"
06-30-2018, 04:34 PM #3
Install new wires.
SOLD
06-30-2018, 08:23 PM #4
06-30-2018, 08:24 PM #5
06-30-2018, 09:46 PM #6
Wait you said won't turn over. How could it start if it went turn over. . Solenoid engages the starter to start the engine turning over.
Web.
1997 Outback and stopped looking
06-30-2018, 10:00 PM #7
07-02-2018, 07:08 PM #8
So to make sure I understand. Your motor will turn over but it only starts from time to time.? Are you getting good bright spark to the plugs?
Web.
07-02-2018, 08:00 PM #9
Sorry to confuse...if it turns over it starts....but doesn't turn over or crank other than random luck.
2002 Outback LS
07-03-2018, 10:53 AM #10
Need to check the solenoid by jumping from the hot wire. are you getting power to solenoid coil when key turns? Sounds like switch or starter solenoid
Web.
