Results 1 to 10 of 11
06-25-2018, 01:40 PM #1
Gravity III Balast system darining
Hi All,
I have an 04 Mobius, when I am done surfing or wake boarding at the end of the day I am unable to completely drain my bow bag as well as my ski locker bag. This is leaving quite a bit of extra weight in the boat for hauling down the road. Any tips to get all of this water out of the bags?
Thanks2004 Mobius LS
06-25-2018, 01:56 PM #2
06-25-2018, 02:11 PM #3
the Gravity III is notorious for this, just not the greatest of systems. Like Stazi said, check valves will help. From there you can upgrade the entire system to reversible pumps. It's pricey but a great system.
Scott
2021 Craz
1997 Sea Ray 190
06-25-2018, 03:15 PM #4
Any idea where I can get these check valves?
2004 Mobius LS
06-25-2018, 03:32 PM #5
Wakemakers.com should have them.
2007 XLV Gravity Games
1,100 in each rear locker
1,180 in front
Fresh Air Exhaust
SuckG8
Bunch of other crap
06-25-2018, 03:35 PM #6
You probably have the 3/4” hose so this is the best price I have found.
http://www.fawcettboat.com/pc_produc...waAn7UEALw_wcB
Sent from my iPhone using Tapatalk2017 Moomba Craz
06-25-2018, 05:16 PM #7Senior Member
- Aug 2011
- 2,522
Check valves won't help with the g3 ballast that's an aerator system. You can add a second drain line to the other leg of the bow bag, that will help but you'll never get the bag completely flat without upgrading to reversible pumps and check valves.
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
06-25-2018, 07:54 PM #8Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Turn off the pump when the water stops flowing, raise the wake plate, drive forward with the bow elevated and start the pump again will get most of the water out.
2005 Mobius LSV
325 EFI
06-25-2018, 11:22 PM #9
Not sure if the system is the same as my 2011 and it took me a while to realize this. After bags were down to zero, you can flip the switch off and then back to drain again and it will run for another 30seconds. Do this a few times while raising the bag and your done.
2011 Mobius LSV, V2 Tower, 1100lbs regular side,
750lbs goofy, 370lbs ski locker, 750lbs bow,
flow surf (don't use it thanks to suck gate)
06-26-2018, 09:16 AM #10A Day at the Lake...Priceless
