Results 1 to 3 of 3
Thread: oil coming out of intake
10-16-2006, 12:43 PM #1Junior Member
- Oct 2006
- 3
Took my boat out yesterday and it ran great but when I got home I noticed oil leaking down my driveway. After further investigation I found the oil coming out of the water intake of my boat. Does this mean I've got a cracked block? 1999 Outback Kanga
10-16-2006, 03:50 PM #2
Oil in your water does not have to be a cracked block, it could be something else. You need to take it to an authorized Indmar dealer. Sorry to keep giving you the same old song and dance, but it really is the best thing you can do. Jay Warren Skiers Choice
10-17-2006, 12:28 AM #3Senior Member
- Jul 2003
- 340
I'm having a tough time coming up with a way that oil from the motor could work its way all the way back to the water intake. I would think that if it could it would take enough that your oil level in the engine would be pretty low. I'd be more inclined to check with the transmission and the cooling lines for it. Also if the oil can get out into the water intake, I'd bet that water was able to get in while you were running it. Check your fluids in both and see if either is low or has a white milky appearance. Either way, it sounds like a definite trip to your dealer like dmgx said.
Ballast Intake
By chadgreg in forum General ChatReplies: 1Last Post: 10-26-2007, 06:39 PM -
Replacing air intake cover...need help.
By cj11302000 in forum General ChatReplies: 0Last Post: 06-04-2007, 11:57 PM -
cooling water intake
By 29racer in forum Service & RepairReplies: 2Last Post: 06-27-2006, 12:45 AM -
K&N air intake
By Brewer in forum General ChatReplies: 1Last Post: 08-27-2004, 12:00 PM -
Excess Water Intake
By MNFatSack in forum Service & RepairReplies: 7Last Post: 05-29-2004, 04:48 PM
