Results 1 to 10 of 15
    Default ballast pump impellers helix
    Hello all, just curious how often do you have to change your ballast pump impellers? Mine is a 17 but I have 240 hours on her and I run 1100s in the rear, and I've never changed them.
    Also where are the ballast pumps located in the helix? I have a manual but not on me if it's in the manual I'll be good. Thank you!
    Apr 2013
    Knoxville TN
    In my Supra, it was 2-3 years. One started sticking. The other had a slower fill time. So I swapped them all at once.
    If they are working well this season, I would not mess with them.
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    Location - do you have a faux wall against the transom in the back lockers?
    If so, when you look in the engine compartment you will see the ballast hoses from the floor shutoff valves routed to that transom wall.
    2018 Supra SL400
    Thank you!
    Jun 2016
    .." change your ball at pump impellers?"
    Sorry, but what are you guys referring too? What is the ball?
    2019 MAX
    2001 Supra Sunsport SSV- SOLD
    Mar 2018
    ALABAMA
    Quote Originally Posted by flienlow View Post
    Think it was suppose to be "ballast pump impeller"
    2017 Moomba Helix
    Flow 2.0
    AutoWake
    Surf Edition
    WM Rears 1200s
    Fresh Air Exhaust
    Fat Sac 400s (Midship compartments)
    LeadWake bags
    Mar 2018
    ALABAMA
    Quote Originally Posted by jobu View Post
    Look in the rear starboard compartment, back carpeted wall, there are 2 silver screws on top of the back wall, remove them, the wall will lift up out of the lower track, and the pumps are behind the wall.
    2017 Moomba Helix
    Flow 2.0
    AutoWake
    Surf Edition
    WM Rears 1200s
    Fresh Air Exhaust
    LeadWake bags
    Apr 2013
    Knoxville TN
    Thread Title "ballast pump impeller".
    On reversible pumps, that is the only thing that you can replace.
    If you want to get real technical, you can also replace the motors or have those rebuilt, but we are talking about an impeller thread in the title.
    2018 Supra SL400
    May 2018
    Atlanta, GA
    Those of you who have replaced the impellers...
    Is it easier to unbolt and unhook the Jabsco to replace the impeller on a bench or is there enough access to do them in-boat?
    2022 Supra SL 400 ordered!
    2019 Supra SL 400 passed on for summer fun
    2018 Supra SL 400 Arrived and awesome!
    2014 Axis A20 - Sold to a great family
    1992 Supra Comp T6SM
    1999 Nautique Super Sport
    Apr 2018
    Texas
    Quote Originally Posted by Ryann View Post
    Just did mine yesterday in the boat took the cover off that hides them. And it’s three screws really simple to replace
    2015 Mojo
    2005 Yamaha at-230 sold
    2012 Ram 2500 tow rig
