Results 1 to 10 of 11
Thread: Prop help
    Jun 2018
    Default Prop help
    Since I started using a surf gate and loading up twice as much ballast (3500-400lbs). Boat seems to struggle to maintain surf speed. And a harder time getting there. I have the original prop now. I know I should go down in pitch but not sure what pitch to buy. Any thoughts ?? Cheers. Jason.
    2008 XLV
    4000 lbs ballast. Full Exile sound system
    Aug 2011
    Commerce Lake, MI
    Quote Originally Posted by Mitty17 View Post
    What boat do you have?
    2017 Moomba Craz
    Jun 2018
    2008 XLV. With upgraded ballast. I think the prop I have is an OJ 14.25 / 17.25
    2008 XLV
    Aug 2011
    Commerce Lake, MI
    Wow. That’s a lot of pitch. Someone was selling a stock 14.25x14.5” prop from a Craz. This would definitely be a move int the right direction.
    2017 Moomba Craz
    Jun 2018
    Ok. Thx. Are the shafts the same? Will a prop off a newer moomba fit?
    2008 XLV
    Aug 2011
    Commerce Lake, MI
    Yes they are both 1-1/8” shafts with left hand rotation.
    In another thread an XLV owner found that the ACME 1847 was the best prop for his heavily loaded XLV.
    https://forum.moomba.com/showthread....ight=prop+test
    2017 Moomba Craz
    Jun 2018
    Thx!! I really appreciate your help! Cheers
    2008 XLV
    This is worth a read.
    https://forum.moomba.com/showthread....LSV-Prop/page4
    Based on this recommendation I went with the 2315 for my ‘07 LSV. My bag capacity is 4k lbs of ballast but I’m probably getting 3500lbs +/- . I went from a 1433 to the 2315 and dropped 400RPMs at surf speed. Yes you will likely need to shim your prop but it takes half the time it does to change the prop and is $25 shipped from boatmate (or make your own for less than $10)
    At the very least call Acme directly. Then call Delta Prop or Nettles to buy it.
    2007 LSV
    2315 Acme prop
    Gravity III + 3 Johnsons
    1100s in the rear, IBS upfront
    Stock bags under the seats
    HDPE Surf Platform
    Aug 2011
    Commerce Lake, MI
    Quote Originally Posted by Leebo View Post
    Shim the prop? How, it’s one tapered mount??? First I’m hearing of someone doing this. Please elaborate.
    2017 Moomba Craz
    Quote Originally Posted by Stazi View Post
    My bad, sorry... shim the trailer.
    2007 LSV
    2315 Acme prop
    HDPE Surf Platform
