Thread: Prop help
06-18-2018, 11:30 AM #1Junior Member
- Jun 2018
- 9
Prop help
Since I started using a surf gate and loading up twice as much ballast (3500-400lbs). Boat seems to struggle to maintain surf speed. And a harder time getting there. I have the original prop now. I know I should go down in pitch but not sure what pitch to buy. Any thoughts ?? Cheers. Jason.
2008 XLV
4000 lbs ballast. Full Exile sound system
06-18-2018, 02:41 PM #2
06-18-2018, 02:45 PM #3Junior Member
- Jun 2018
- 9
2008 XLV. With upgraded ballast. I think the prop I have is an OJ 14.25 / 17.25
2008 XLV
06-18-2018, 02:47 PM #4
06-18-2018, 02:49 PM #5Junior Member
- Jun 2018
- 9
Ok. Thx. Are the shafts the same? Will a prop off a newer moomba fit?
2008 XLV
06-18-2018, 02:55 PM #6
Yes they are both 1-1/8” shafts with left hand rotation.
In another thread an XLV owner found that the ACME 1847 was the best prop for his heavily loaded XLV.
https://forum.moomba.com/showthread....ight=prop+test
06-18-2018, 02:58 PM #7Junior Member
- Jun 2018
- 9
Thx!! I really appreciate your help! Cheers
2008 XLV
06-18-2018, 07:01 PM #8Member
- Aug 2013
- 84
This is worth a read.
https://forum.moomba.com/showthread....LSV-Prop/page4
Based on this recommendation I went with the 2315 for my ‘07 LSV. My bag capacity is 4k lbs of ballast but I’m probably getting 3500lbs +/- . I went from a 1433 to the 2315 and dropped 400RPMs at surf speed. Yes you will likely need to shim your prop but it takes half the time it does to change the prop and is $25 shipped from boatmate (or make your own for less than $10)
At the very least call Acme directly. Then call Delta Prop or Nettles to buy it.2007 LSV
2315 Acme prop
Gravity III + 3 Johnsons
1100s in the rear, IBS upfront
Stock bags under the seats
HDPE Surf Platform
06-18-2018, 07:09 PM #9
06-18-2018, 07:28 PM #10Member
- Aug 2013
- 84
