Results 1 to 10 of 12
    Oct 2017
    Maine
    Default Need help Got water locked on 2 cylinders after flaps failed 01 mobius v
    01 Mobius V with the 350 indimar(chevy) carb
    All my issues have stemmed from once incident, I was out and the ignition wire fell off(has to mess with it a few days before at the dock). At the time I didn't have exhaust flaps, they showed up the next day. So when I stalled when the ignition wire fell off water was sucked into 2 cylinders. The engine was in lock, at this time I thought it was the starter, got it rebuilt, reinstalled and found it wasn't the started. I pulled the plugs and found water in 2 cylinder on opposite sides of the motor (#1 on port, #4 on starboard). Pissed the water out, oiled the cylinders, and replaced all plugs. Motor now runs, it starts hard cold and warm, but will idle slightly rough at 700-800 rpm. I took it out for a spin and can only do maybe 25-30ish MPH and only get to 3500 RPM compared to 4500 plus. The boat also lacks the punch it used to have when you drop the throttle, and even after its warm you must advance the throttle to start it, this was never a problem before. It also smells slightly of gas when running, but no visible signs of leaking. It does idle once warm.
    What is everyone's guess? Or places to start.... I'm thinking compression test to rule out a bent valve. Its not the throttle cable I checked, that would just turn up or down the idle. Any other ideas of places to look or ideas? I just pray I don't have to pull the heads and deal with that but looking that way.
    Thanks, had a great year started, always remember to check your exhaust flaps, the boat was new to me and I was so excited to put it in the water I didn't order them soon enough.
    2001 Moomba Mobius V
    Sep 2015
    Conroe, TX
    If you tried to start it with the cylinders full of water you may have bent a connecting rod. You’d have 2 cylinders with lower compression to explain the power loss and rough idle.
    That would be my initial guess
    Overkill is underrated
    2006 Supra 24SSV Gravity Games- traded but never forgotten
    2017 Supra SA 400
    Oct 2017
    Maine
    Wouldn't that make the engine tap not lose power?
    May 2018
    Bent rod will cause power loss
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Apr 2018
    Texas
    The rod travel won’t be the same cause loss of compression loss of power
    2015 Mojo
    2005 Yamaha at-230 sold
    2012 Ram 2500 tow rig
    Have you ever looked at the water flow in these motors? I fail to understand how you can suck water into the cylinders on a v drive even without flaps. Rusted or Cracked exhaust manifold, improper winterization, head gasket seem more likely to me. Looks like you got the boat last fall. Did you do the winterization? How many hours have you put on it this year? Why were your messing around with the ignition wires in the first place? Just trying to gather all pertinent information. If you bent the rod like above, the cylinder walls will be scored to crap by now with wrist pin angles changed
    99 Outback LS. Sold
    Oct 2017
    Maine
    Update, looked everything over. I did have water in the oil, but the real issue was when the plug wires were put back on incorrectly. I checked a diagram and found this was the issue causing the loss of power and gas smell. As for the water in the oil this was expected because water got in the motor. I changed the oil 4 times until the milklyness came out and took it for a ride. No further milkyness, telling me no bent valve, rod or head gasket. Changed the oil 3 more times over the next day each time a longer and longer ride, the last I put 4 Hrs on Saturday. Oil is still clean, I dodged a huge bullet here.
    DOCDRS- I put 20 hrs on already this year with no problems. Yes winterization (in Maine definitely needed!), Originally messed around with the ignition wire because the starter selonoid was going (replaced in this ordeal) and the female end was night tight on the male connector (I've fixed).
    I don't believe it sucked water in, but as the engine stalled at speed the wave blew water in and while it was stalled there was no exhaust flow to push the water out.
    My only issue now is after running and warm if I turn the boat off I need to advance the throttle to restart then can jump back to idle. Before I could just start in neutral after it was warm. Maybe it will shake it, I will replace spark plugs again. Currently running a little seafoam in oil before I change it again tomorrow.
    Thanks for all the advice and imput, like I said dodged a bullet, check your exhaust flaps!
    May 2018
    Glad it was operator error. Pride is easier to fix than rebuilding an engine.
    2021 Supra SA 400
    Michigan
    so i am in nh and yes winter prep is huge, as for your engine, start with compression and leak down , i do not understand how water got into the oil but its 2 different sealed systems so be careful
    I am glad it all worked out, I guess you can get water from the exhaust into the cylinders under the right conditions.........still baffles me but it seems to be the only logical way if all is good. keep up posted if things stay good or change.
    99 Outback LS. Sold
