Results 1 to 1 of 1
05-30-2018, 11:30 PM #1
Perfect pass not reading speed correctly
Hello all, 2005 LSV with paddle wheel perfect pass.
After being in storage over the winter, first couple times out haven't been able to get perfect pass to work. It seems to read speed consistently when the system is turned off, so have just been manually controlling speed. When the system is turned on it will read out speed but while maintaining steedy speed, perfect pass then displays wild reading from 9-16mph (this was done while surfing)
I know the actual speed wasn't changing based on factory speedo and engine rpm, and wave for the mattee.
Any ideas on if it is just a setting or bad hardware/paddle etc., or is the firmware updateable2005 Moomba Mobius LSV
