Results 1 to 8 of 8
    Jun 2016
    Default 2015 OBV bow bag
    I have a stock gravity III ballast system. Recently just bought a 750lb bow bag does anyone have instructions on how to pipe it in on center bag. I DO NOT want to use an external pump anymore!
    The new bag is a Sumo.
    Jul 2015
    noblesville, in
    I piggy backed my bow bag off the center tank. Super easy to do. I'm on the road for work but I'll try to get you more info over the coming days. Wakemakers can also talk you through it on the phone.
    Karl
    2014 Outback V
    Aug 2012
    Morganton, NC
    I did the same as Karl, here's my setup - worst part was pulling the center bag out to get the 90* fitting in and drilling the 1 1/4" hole in the floor of the front locker (not hard but nerve racking!)
    I left a 'service loop' in the fill hose to ease the alignment of the tail of the bag and fitting through the floor:
    2008 OBV
    325 EFI with closed cooling
    Gravity III with 750's in the rear, 400 stock floor, 750 IBS
    Servo valve ballast upgrade
    Wetsounds Rev10
    JL Amps, WS420BT
    2000 Outback LS <-- Sold!!!
    310 Carb Direct Drive
    800# Rear Locker
    750# IBS (should have kept this for the OBV)
    Dual Batteries with 2 Bank Charger System
    Kenwood Head with Remotes
    Too many hours restoring exterior from prior negligence to count!
    Jun 2016
    Is there any way of doing this with out drilling ? How much should it cost?
    Aug 2012
    Morganton, NC
    Quote Originally Posted by Richied718 View Post
    No not that I'm aware of. I installed mine in about 30 mins so shouldn't be much cost
    2008 OBV
    Wetsounds Rev10
    JL Amps, WS420BT
    800# Rear Locker
    Jun 2013
    I don't really recall how I routed the hose but I didn't need to do any drilling in my 2013. Maybe there is some difference in the model years that the 2008 needs to have a hole drilled but the later models don't??
    The only cost I had was a few clamps, a new section of hose and the IBS sack itself.
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Jul 2015
    noblesville, in
    I also did not have to drill any holes in my 2014 either.
    Karl
    2014 Outback V
    I did. The only access to below was either under the hump in front of the driver's feet or in the cubby where the battery cables, etc. come up. I drilled a hole half way up the bow so I could run from the center bag to the top of the IBS bag without kinking.
