Results 11 to 18 of 18
Thread: Reusing factory ballast bags
05-29-2018, 09:48 PM #11
I see what you are trying to do. You may be better off selling those bags and buying some others. Your scenario, and a few others is why I called fatsac as well as flow-rite today.
2011 Sea-Doo Wake 155
05-29-2018, 10:02 PM #12
I figured out a solution. Use quick connect fittings and universal tsunami fittings with 1" hose, that will take care of your fill and drain on the top. For the side port, 2 quick connect fittings on either end of some hose with quick connect plug. I would suggest a 90 and a straight. All the fittings, hose, and plugs can be found through wakemakers and fatsac. Use clamps to secure everything. So, about $100 in parts and an hour of work to be able to reuse them. If the bags don't have the air release fittings, buy those as well. Its the long way around, but it would work.
05-29-2018, 10:30 PM #13
05-29-2018, 10:33 PM #14Member
- May 2018
- 34
05-29-2018, 10:42 PM #15
Smart man, but showing that it is possible. Lol.... MJH, I am good at demolishing factory bags.
05-30-2018, 12:11 AM #16Senior Member
- Mar 2018
- ALABAMA
- 202
05-30-2018, 10:24 AM #17
Man don't give up yet, this is actually easy with the right tools. You will need hair dryer, large paint stick, and a dowel the size of the fitting. Heat with the dryer for 10 minutes on low but high heat. Use the paint stick to stand on and hold the edge down while you insert the dowel to pry the fitting loose. I just did 2 bags and total took me about 11 minutes per fitting and nothing ruined. Dealer told me there's no way and then I found the wakemakers video on here on modified the procedure a little.
05-30-2018, 10:42 AM #18
