Results 1 to 3 of 3
    Apr 2015
    Default Shaft seal on 2015 LSV leaking
    I have a steady stream of water coming in through my shaft seal. My boat has less than 100 hours so that’s a bummer, but it is what it is. My question is: can the seal be tightened? I loosened the hose clamps and was able to slide the hose/seal up and down the shaft, but couldn’t figure out how to tighten the seal (brass fitting). I’ve read all the other threads about repacking/tightening the large nut. Problem is my boat doesn’t have that adjustment nut. Ideas?
    May 2018
    Dealer and warranty
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Jan 2015
    Live: OP, KS...Boat: Shell Knob, MO
    I’m dealing with this right now. Based on year of boat I’m sure you have a dripless shaft seal, not to be confused with the older style with a packing nut that is adjustable and supposed to drip at a define rate.
    Does yours look anything like this?:
    2013 Mojo
