Results 1 to 3 of 3
Thread: Shaft seal on 2015 LSV leaking
05-27-2018, 05:23 PM #1Junior Member
- Apr 2015
- 4
I have a steady stream of water coming in through my shaft seal. My boat has less than 100 hours so that’s a bummer, but it is what it is. My question is: can the seal be tightened? I loosened the hose clamps and was able to slide the hose/seal up and down the shaft, but couldn’t figure out how to tighten the seal (brass fitting). I’ve read all the other threads about repacking/tightening the large nut. Problem is my boat doesn’t have that adjustment nut. Ideas?
05-27-2018, 06:57 PM #2
Dealer and warranty
2018 Supra SA 400 (SOLD)
Michigan
05-30-2018, 12:38 PM #3Senior Member
- Jan 2015
- Live: OP, KS...Boat: Shell Knob, MO
- 167
I’m dealing with this right now. Based on year of boat I’m sure you have a dripless shaft seal, not to be confused with the older style with a packing nut that is adjustable and supposed to drip at a define rate.
Does yours look anything like this?:
2013 Mojo
