Results 1 to 2 of 2
    May 2003
    south east michigan
    Default water pump wobble
    I have a 2003 outback LS. Just pulled it out of the water and did the first oil change.(engine and trans) everthing went smoothly except when i was warming the engine up to check the trans level i noticed a small amount of "wobble" in the water pump. Is this normal or should it sit perfectly steady?
    jy
    Aug 2002
    Maryville, Tn.
    Default Wobble in pump
    The pump will have some wobble to it, this is common with the Johnson pump on the Indmar motors and will not be an issue. If it is wobbling to much, and you feel it will have long term effects, tell the dealer, and have it looked at during your next service.Brian Raymond
  1. Raw Water Pump Removal
    By dtlaine in forum Service & Repair
    Last Post: 07-10-2008, 04:11 PM
  2. Water Pump Leak
    By tlrowe in forum Service & Repair
    Last Post: 08-14-2007, 07:52 AM
  3. Raw Water Pump
    By TobesDubai in forum Service & Repair
    Last Post: 03-03-2007, 08:23 AM
  4. Indmar Water Pump
    By moombamania in forum Boat Owners
    Last Post: 06-12-2003, 11:04 PM
  5. water pump
    By Mainemoomba in forum General Chat
    Last Post: 06-09-2003, 10:05 PM
