Results 1 to 8 of 8
    Default Prop talk...To Prop or not to Prop
    I have a 2017 SA 400
    After we are done surfing and I want to rip into to party cove I have a heck of a time getting the boat on plane with the Acme 2775 15x12.5 prop I have. This is with pretty much full ballast other than maybe 20% in the starboard rear locker and an additional 750 lbs of lead spread in various places.
    My dealer is telling me that I need to go down in pitch and that I should get a 15x11.5 from what I read on here people are doing the OJ 945 which is a 15x13. Which prop do I want to assist in getting the boat on plane with full ballast?
    Also my understanding is the center plate always deploys to assist in getting the boat on plane, but if I want to use the Supra "launch" system where all 3 plates deploy I have to have autowake on to deploy all 3 tabs then turn it off once planed out and up to speed?
    I am in DFW area so elevation is not a concern.
    2018 Supra SL550 with 850lbs of lead wake
    2017 Supra SA400 (Sold)
    2021 GMC Denali 2500
    Soulcraft Vodoo
    Soulcraft Jordi Pro
    Soulcraft Super AV
    Phase Five Matrix
    Aug 2011
    Commerce Lake, MI
    Quote Originally Posted by Prospersigman View Post
    Yes, you have to be in autowake to get all three tabs to deploy on take off. You can do this and then either put it into manual or cruise after you’re up on plane. I don’t think you need a lower pitch prop as I have the OJ 945 and it does just fine with 4000 pounds of water on board.
    2017 Moomba Craz
    Dec 2015
    north texas
    Have you tried advanced wakeboard setting with autowake on? Turn off aw once going.
    2017 Supra SA
    Oct 2010
    Lake Wylie NC Area
    What engine and gear ratio?
    Sep 2015
    UT 6000'
    I thought on Supra you can turn on LAUNCH without Autowake? You have a prop that will do the job, I'm crazy higher elevation and can get the 400 on plane fully loaded.
    DFTR Josh
    Supra/Moomba
    www.marine-products.com (Discount Code: DFTR-1)
    I must be because I am not turning on autowake...I typically never use autowake for either surfing or wakeboarding. I'll try that and report back.
    Soulcraft Vodoo
    Soulcraft Jordi Pro
    Soulcraft Super AV
    Phase Five Matrix
    Aug 2011
    Commerce Lake, MI
    In a Moomba, as far as I know, the only way to use the launch feature, which only works in wakeboard mode, ie the surf switch is neutral, is if you are in Autowake mode.
    2017 Moomba Craz
    Sep 2015
    UT 6000'
    I just picked up a 2017 SA, I'll see what I can figure out also.
    DFTR Josh
    Supra/Moomba
