Results 1 to 8 of 8
Thread: Trailer Start
    Jul 2009
    Syracuse Utah
    Default Trailer Start
    Hey Guys,
    I’ve got a 2013 LSV. I just changed the engine and v-drive oil, as well as the transmission fluid. If I hook up water to the engine and start the boat at home, what would happen if I put it in gear? I am thinking about letting the propeller troll at low RPM to get the fluids good and mixed in.
    Thoughts?
    2013 Moomba LSV
    Not a good idea. There is no resistance on the prop (water).
    May 2010
    Salt Lake City, Utah
    I have done this from time to time without any issue at all. There is water dripping down the shaft to keep it plenty wet and I have also sprayed some wd 40 as well just to make sure there is no friction at all. I probably wouldn't let it run for a long time but I don't think it is a problem to run it for a few minutes.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Mar 2003
    Springfield Missouri
    The prop turns in air on my boat while in neutral just from the hydrostatic friction.
    1998 Mobius
    310 HP PCM
    SOLD
    Oct 2013
    Ft. Collins, CO
    Quote Originally Posted by Davpmars View Post
    Why? I can't think of any benefit vs. just putting it in the water and going.
    1989 Sanger Skier DX - sold
    Nov 2016
    Knoxville, TN
    There is a shift lock override button at your throttle. You can engage that button and move the throttle out of neutral to rev the engine without the transmission engaging.
    2011 Sea-Doo Wake 155
    Aug 2011
    I do a quick 15-30sec check, if you're worried spray some water on the cutless bearing, that's the only thing you can harm if you go for longer and make sure nothing hits the prop.
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
    May 2016
    West Milwaukee, WI
    The packing gland needs water cooling too. Not necessary IMHO, but if you must, don't do it for more than a few seconds or more than idle speed.
    Save this step for on the lake.
    2004 Mobius LS - hooked on footin'
    Former tow: 1986 Chaparral 178 XL, 90hp Merc
    First tow: 197x Glasspar Citation, 135hp Merc
