Results 1 to 10 of 22
Thread: Ballast bag fittings issue
05-20-2018, 05:20 PM #1Member
- Jun 2015
- 80
Anyone else having their fittings continually pop off on their Max? I’ve repositioned bags numerous times. Even if I only fill them 3/4 they still pop off.
2014 Moomba LSV
2018 Moomba Max
05-20-2018, 05:52 PM #2Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
If you haven't used PVC cement to glue your threaded fittings to your bags that is going to happen.
2016 Mojo Surf
Raptor 400
1100 rear bags / 500 IBS / 600 LeadWake
Exile amps/tower - Kicker in-boat
FAE
05-20-2018, 05:54 PM #3
Factory setup or aftermarket sacs? Threaded fitting coming out of threaded sac port or quick connect coming off sac fittings?
05-20-2018, 05:57 PM #4Member
- Jun 2015
- 80
Factory setup. Female quick connectors popping of male fitting on the bags
2014 Moomba LSV
2018 Moomba Max
05-20-2018, 06:39 PM #5
They should have red push down clips that you engage after putting the fitting on. Do yours not? Any photos? Those always help.
2011 Sea-Doo Wake 155
05-20-2018, 07:00 PM #6Member
- Jun 2015
- 80
Yep, they’re engaged. When I put them back on and tug on them they stay connected, one fill and they pop off
2014 Moomba LSV
2018 Moomba Max
05-20-2018, 07:11 PM #7
Is it the fill/drain line or the overflow? That is really strange.
05-20-2018, 07:18 PM #8Member
- Jun 2015
- 80
All 4 fill/drains. there’s 2 on each bag. It’s weird.
2014 Moomba LSV
2018 Moomba Max
05-20-2018, 07:24 PM #9
I had an issue with one of my fittings popping out of the bag itself. I ended up unscrewing the clamps holding the hose to the deck that way it could flex and articulate some. That fixed my issue. Not saying yours is doing that, but it is an easy place to start. You may want to get your dealer involved. That is a lot of water your bilge is having to pump out.
05-20-2018, 07:25 PM #10
Id look close at the black part of the fitting where the red locking collar travels on, may find its broken. This is usually the case when the collar acts like its locked but the fitting still pops off.
