Results 1 to 10 of 12
Thread: 2018 moomba craz questions
05-19-2018, 07:38 PM #1Junior Member
- Dec 2016
- 21
Hi,
New boat, first time out on the lake today and I have a couple questions.
1)on the autoflow, my plate is only going to 60, I think it should be going to 100, how do I adjust that?
2) there was only 2 of us on the boat with 3000 lbs of ballast and the wave wasn’t the greatest. Do we need to get some lead if that is all the people we are going to have In there?
3) struggled with autowake today, any tips or should it just work?
Thanks. Devo
Awesome boat though
05-19-2018, 07:50 PM #2
05-19-2018, 08:44 PM #3
Turn off auto wake a dial it in yourself.
2011 Sea-Doo Wake 155
05-19-2018, 11:02 PM #4Junior Member
- Dec 2016
- 21
You can adjust the deployment of the surf tabs with the up and down arrows on the screen.
Is it the buttons below or the arrows themselves? I tried hitting them and nothing seemed to happen, will try again.
I also turned autowake off and try to dial it in myself and still was barely surfable. When you are using autowake, do you manually fill your bags and then turn autowake on or turn autowake from the start and it will do everything?
Thanks again
05-19-2018, 11:34 PM #5Senior Member
- Apr 2012
- Lexington, SC
- 542
How close are you to the dealer? Did your dealer do a water test with you upon delivery of the boat? At these prices I would expect my dealer to demo/water test the boat with me and help dial it in. Just my two cents. Sorry I can't answer your specific questions. Maybe your dealer or a forum member in your area.
05-20-2018, 12:39 AM #6Junior Member
- Dec 2016
- 21
Dealer was great, just different when you get the boat out on your own.
05-20-2018, 09:10 AM #7
05-20-2018, 09:27 AM #8
Read this thread thoroughly:
AutoWake questions
https://r.tapatalk.com/shareLink?sha...0&share_type=t'08 Mobius LSV- SOLD!
2017 Mojo Pro
05-20-2018, 12:10 PM #9
On an 18 you will have to turn auto wake off then use the said up and down arrows to adjust your plates , so flip autoflow switch to the side you want to surf with no autowake, then you adjust your plates , once you get the plate where you want it turn auto wake back on, have had the best luck not going over 70% for port surfing, wake plate 30% or less. 3000 is a little shy for smaller crews but it is very doable once you figure out how to maximize what you have.
2017 Craz surf auto wake
1140 # rears wet sounds
05-20-2018, 01:15 PM #10
Fill bags first, then turn on auto wake If you want to use it.
