Results 1 to 10 of 39
Thread: Adding dual pumps per bag
05-12-2018, 09:19 PM #1
I need some help guys. Who has a 2018 boat with the g6 ballast? Would you be willing to take some pictures of the wiring for me? The PDM is located behind the panel at the back of the port locker. I would like to see how the factory has wired the 2 pumps per bag to the pdm. Thanks in advance!
'08 Mobius LSV- SOLD!
2017 Mojo Pro
05-16-2018, 08:45 AM #2Senior Member
- Apr 2015
- 169
I am interested in trying this as well. If I recall some of the other posts on the subject it sounded like they had 3 new relay based ballast modules for the 2018 models so maybe they wired the on/off from the pdm out to the relay modules so they could keep the timer function controlled from the screen? That would be ideal because if you have the correct power to energize the relays I think you could do a spst combined dpdt relay setup to properly control the on/off and reversing polarity of each new pump without adding any more current draw to the pdm. Pictures would definitely be helpful!
Not to hijack the thread but if someone does snap some pictures of the wiring could you also take a pic of the where the plumbing splits? Is it right after the through hull?2015 Mojo with autoflow
05-16-2018, 09:34 AM #3
05-16-2018, 10:34 AM #4Senior Member
- Jan 2018
- Lexington, KY
- 369
Single line from the ball valve to a Y just upstream of the pumps.
There are 4 relays on this (port) side. Orange wire from each pump turns red at a connector then go to seperate relays. I didn't trace it all but I'm thinking one power relay per pump, and one reversing relay? What does a boat with only 3 pumps look like? Center pumps are between the fuel tank and ballast tank under the deck. I'm assuming stbd pumps are behind the similar panel on that side. I didnt see relays for the center pumps, obviously they've got to be somewhere...
I was up there remote troubleshooting my depth finder/water temp issue on the phone with my dealer.
Sorry for the not so greatbpic, it's as far as I had time to dig into it right now.Last edited by korey; 05-16-2018 at 10:38 AM.
2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
05-16-2018, 10:55 AM #5
Thanks. When you have time, can you take a clear pic of the relay module on the top right of the board? It is shrouded with wires in this pic. I am assuming that is a relay module, as I don’t have that and the pdm looks identical. On my boat with 3 pumps, the pdm wires go directly to the pumps, with no relays in the mix.
2017 Mojo Pro
05-16-2018, 11:16 AM #6Senior Member
- Jan 2018
- Lexington, KY
- 369
Derp, I can't believe I didn't get that picture. I did pull the shroud off of the relay module and trace wires. I'm at work now, but I'll snap a picture of the relays before I put it back together now that I know there are none on yours... might not be tonight, but definitly by the weekend.
05-17-2018, 09:47 AM #7Senior Member
- Apr 2015
- 169
What pump are you planning on adding? Looks like the stock one is model # 18670 which according to google is only 480 gph? If we are moving to relays any reason the second pump couldn't be a bigger pump like the ballast king or the wakemakers branded pump that claims 720 gph?
05-17-2018, 10:06 AM #8Senior Member
- Jan 2018
- Lexington, KY
- 369
I hope thus helps, no time for me to trace wires this morning - this reminds me too much of working on a boat, and that's the reason I bought a new one!2018 Moomba Craz | Autowake 2.0, Zero-Off, G6 Pumps | Captain Blue/Dark Graphite/Silver Flake | Enzos + Lead
05-17-2018, 12:36 PM #9Senior Member
- Aug 2011
- 2,522
How about the relay model numbers..
2006 Moomba Mobius LSV - Sold
05-17-2018, 12:39 PM #10Senior Member
- Apr 2015
- 169
Looks like it is listed on the case in the picture he posted. Hella 931680011.
