Results 1 to 3 of 3
Thread: Swim platform
05-12-2018, 06:07 AM #1
Swim platform
How much play is normal on the swim platform? When sitting in the water, if a wave hits the boat and pushes up the platform moves up maybe a 1/4 inch.
Sent from my SM-G955U using Tapatalk2017 Moomba Mondo
1120 rear lockers
500 center hard tank
750 ibs
2-650s in the floor
Acme 2079 prop
05-19-2018, 09:56 PM #2Senior Member
- Oct 2013
- 135
I put composite door shims in mine helps a lot once you tighten up the set screws it stays tight
Sent from my iPhone using Tapatalk2013 outbackv
05-20-2018, 12:14 PM #3
Other people put a stainless lock washer down in the crack. You can get it out with a needle nose pliers if you need to.
