Results 1 to 6 of 6
05-07-2018, 02:26 PM #1Member
- Aug 2016
- 63
Transmission and V drive fluid change
Stupid question.
I have an extraction pump i used to change oil in my cars, jet ski and moomba.
Can i use the same extraction pump for the Vdrive and Transmission? Just wondering if the tiny bit of oil at the tip of the hose will contaminate anything?
I"m assuming it's ok to use the same pump on the V drive and transmission?
I don't have much mechanical skill or knowledge, pretty much oil change is all i do.
Thanks!
05-07-2018, 02:40 PM #2
Wipe it off. I use my pump for everything.
05-07-2018, 02:41 PM #3
I rinse the hose with brake cleaner, it dries in minutes
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
05-07-2018, 02:52 PM #4Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
05-08-2018, 10:23 AM #5
great for everything.
Scott
2021 Craz
1997 Sea Ray 190
05-08-2018, 03:09 PM #6Member
- May 2018
- Little Rock, AR
- 35
Yes. After each change would make sure to drain tube with gravity. Sticking tube in one of the high holes in a garage door track was just about ideal.
'14 Mojo 2.5
