Results 1 to 8 of 8
    Apr 2018
    Default Another (blank) ballast thread. 2003 LSV.
    I have searched and searched.
    1- does everyone just over weight their boat?
    I only have the stock ski locker ballast now.
    My plan was to purchase the 50x24 inch big bag at around 800lbs
    On surf side. https://www.wakemakers.com/launch-pad-800-single.html
    And a tube of some sort for the walkway in the bow.
    https://www.wakemakers.com/straight-...llast-bag.html
    I have found shorter ones but they are wider and my walkway isn’t that wide.
    I’m on a natty light budget ��
    I have 4-8 people on the boat often. Wave shaper on none surf side.
    Nov 2016
    Knoxville, TN
    If you are running a wave shaper, you will want to weight the back as even as possible with a slight list to the surf side. So you would need 2 bags for the rear and a pump. That new Supa Tsunami pump from flyhigh is really nice.
    2011 Sea-Doo Wake 155
    Apr 2018
    Do I need the big 800’s on this little boat or the 540’s do the job?
    Killing my storage lol
    Nov 2016
    Knoxville, TN
    I was going to suggest 600s. Does your boat have a hydraulic trim plate? The heavier you go in the back, the more you will need up front or the faster you will have to go to not have a wave right on top of your platform. Surfing and getting a good wave really is a numbers and physics game with all the variables.
    Apr 2018
    No trim plate
    Nov 2016
    Knoxville, TN
    Ok, start with 600s in the rears and add the bow weight. Good luck!
    May 2017
    Alberta, Canada
    Someone correct me if I'm wrong but I think the 2003 LSV hull is same as 2005 LSV hull. From my own research and experience, I believe our hull needs a lot of weight to get a decent wave rolling. I wouldn't do less than full 750's in the back, full 400 in the center and full 250's under front seats. I would start there and then depending on how many people you have, you can fill some spare bags and place where needed.
    Definitely have to turn correctly/carefully when you are picking up after a fall, or you will have water swamping over the bow. Also need a good prop to push all that extra weight but if you want a larger wave....
    2021 Mojo, 6.2L Raptor 400/1.76, Acme 3407 15.5x13, G6, Flow3, +6500 lbs ballast
    2005 Mobius LSV (sold)
    Windermere Lake, B.C., 2800' Elevation
    2021 Mojo Mods
    Apr 2018
    So we are definitely over loading the boat? ��
    Is there an issue putting a 50” long bag in the back that is only 46”?
    Thanks a ton for the direct answers.
    I don’t need Perfect... just usable.
    It’s just social hanging out with friends.
