Results 1 to 3 of 3
10-04-2006, 08:05 PM #1Senior Member
- Jan 2004
- Austin, TX
- 145
Is 2006 Outback V the same hull as the 2004 Mobius LSV???
Can anyone confirm that the 2006 Outback V is the same hull/cover dimensions as a 2004 Mobius LSV? I am looking at buying a non-puddle pole trailerable cover made for my 2004 Mobius LSV by CoverCrafts (which makes fantastic covers for Malibus). However, they haven't made a cover for a 2004 Moomba Mobius LSV yet. They have obtained access for a 2006 Outback V for measuring and fitting the cover (which the dealer tells CoverCrafts that the Outback V is exactly the same boat as the 2004 Mobius LSV). Can someone definitively confirm one way or the other, that this is correct? I don't want to proceed with the deal if there is a chance the cover won't fit my boat perfectly.
In case you were curious, the cover that came with out 2004 boat is worn out already and never worked worth a darn. The poles were worthless - in spite of all changes, we could not prevent huge puddling on the cover after rains. We ended up with significant additional structuring under the cover to prevent puddling. However, after 2 plus years, the cover is torn at the front poling seam. Getting it repaired seems pointless.
Please let me know ASAP. Either I will go with the CoverCrafts cover or the Rankin. Thanks.
10-04-2006, 08:14 PM #2Junior Member
- Aug 2006
- 16
Yes, they are the same boat (2005 and under). I'm picking up our 2007 Outback V on Friday!
Hope this helps!
Craig
10-05-2006, 01:01 AM #3Senior Member
- Oct 2005
- Central FL
- 791
YES
2003-2005 Mobius LSV is now the 2006-2007 Outback V.
Same hull, same tower.
-J
Looking for 2004 to 2006 LSV
By DLC2008 in forum Moomba ClassifiedsReplies: 0Last Post: 07-03-2007, 04:11 PM -
LS hull worth it over standard outback for wake?
By GuitsBoy in forum Sales & InformationReplies: 7Last Post: 03-29-2007, 08:32 PM -
more mobius & outback hull questions ???
By bobwells in forum Sales & InformationReplies: 3Last Post: 01-22-2007, 09:08 PM -
2006 Outback V vs 2006 Mobius LSV
By Gary Hickman in forum General ChatReplies: 2Last Post: 07-28-2006, 10:33 PM -
Hull on Outback vs. Mobius
By mgigr in forum Wakeboarding | WakeskatingReplies: 1Last Post: 02-01-2005, 12:19 PM
