Results 41 to 47 of 47
Thread: Underwater LED install
02-02-2019, 10:17 PM #41
03-14-2019, 04:56 PM #42
Any updates on these installs by chance? I was going to order the Loki, but sounds like it might not be worth the hassle... especially if the wiring isnt rated.
03-14-2019, 05:09 PM #432018 Supra SA400 aka The Ron Burgandy
2011 Sea-Doo Wake 155
07-15-2019, 04:43 PM #44Junior Member
- Jul 2019
- 1
I know this has been covered somewhere, but those wires that are pre-ran, are they the black and yellow wires that are plugged into one another? That’s the only wires I see back there with pig tails. Didn’t want to unplug them and hook up my drain plug lights with out checking first. 2018 Mojo
07-15-2019, 06:46 PM #45
Marine illumination blue. May have a black tracer, but the primary color is usually blue.
07-19-2019, 01:41 PM #46Member
- Oct 2018
- 32
The wires are in the engine bay, against the stern wall on the starboard side (not by all of the junction boxes on the port side).
Take off the black plastic decorative "Moomba" thing for more clearance. You can also remove the starboard side engine/ballast divider panels, although it isn't necessary.
The wires are almost impossible to see without first pushing the bilge vent hose(s) out of the way. Even then, they are zip tied to a horizontal cable run (terminated ends stick out on the starboard side of the wire run), so you can just barely see the wire ends poking out. They are labeled as underwater lights (there are two pairs, btw), so you'll know you have the right ones (and are blue with grey stripe, if I remember correctly). Clipping the wire tie provides enough slack for connections.2017 Moomba Helix
09-08-2021, 09:56 AM #47Senior Member
- May 2020
- Nashville
- 229
Old thread I know but buying some stuff for winter projects. @spatty99 you mentioned 2 pairs. What is the other pair of wires for if not underwater lights or do they belong to a different acc switch?
2018 Moomba MOJO
4100lbs. ENZO's, Center Tank, IBS
780lbs. Lead Wake
Raptor 400
Surf Prop: OJ 945
2019 Ford F150 FX4
5.0L V8
