Results 1 to 10 of 22
Thread: New fusion stereo
04-06-2018, 10:44 AM #1
New fusion stereo
What are the opinions here? Reading up a but seems like maybe a 420 not needed? Addmittedly, the stereo on the craz i demo'd didnt sound great, hoping it just wasnt tuned...
'08 Mobius LS. Sold
'18 Craz "TypeO"
REV10's, Revo6 xss, Kicker10, Kicker 12 CompR, various LED's
04-06-2018, 12:25 PM #2
04-06-2018, 01:02 PM #3
If you are referring to the new models, they no come with the RA70Ni. Major step up from the 205 IMO. Still have 2 zone and woofer IF all speakers are driven by external amps. Integrated BT is WAY better then the old fusion BT-100 universal. The BT-200 was much better, but it occupied the data port for SAT. You get one or the other.
Id be hesitant to pain with too wide of a brush on any OEM installed system. Amp tuning, if you can call it that, it all over the place one boat to the next. Is there a woofer to fill out the system and if so, is it a proper IB model or still missing the needed enclosure as we have seen in the past?
Is a periphrial like a WS-420SQ needed? Still have some benefits, so really comes down to how one wants to use the system and expectations. Its line driver can benefit most any system. Its dual zone 4-ban EQ will certainly benefit any system. 3 zone + master volume right at your fingertips might be better for some, then going into the head unit menu.
04-07-2018, 09:40 PM #4
04-08-2018, 07:04 PM #5
I have a 16 Craz with every stereo option can you give me some tips on how to properly tune. Thanks
04-23-2018, 08:18 AM #6
Ok, read and reread!! I finally got the boat home and was able to play with the stereo. It sounds...ok, but i def see the cabins need replacing. Looking at the revo 6. As for the sub being "ib", im really not sure. Ill do some research on it. Being told i need to add a third amp as well to drive the new cabins...its just money...right???
'08 Mobius LS. Sold
'18 Craz "TypeO"
04-23-2018, 08:56 AM #7It sounds...ok, but i def see the cabins need replacing.
Do you need a 3rd amp? nope. Do you need a new amp? nope. Now with that said, will the factory amp drive a speaker like the revo-6, to its potential? Likely not. Heck the OEM Kicker could even benefit from another 25-50 watt rms. IIRC, the OEM amp is the Kicker KXMA800.5. Very solid, quality amp. 50W rms to each of 6 in-boats is not a bad setup.
04-23-2018, 09:54 AM #8
Hmmmmm, more to think about. Ill play with it more this week. I certainly dont want to spend a grand if i dont need to.
'08 Mobius LS. Sold
'18 Craz "TypeO"
04-23-2018, 10:19 AM #9
04-23-2018, 10:03 PM #10Junior Member
- Mar 2018
- kentucky
- 15
how does the mixture of the 8's and 6.5's sound together. Also how does it look on the tower? Any pictures you could post or DM?
