Results 1 to 10 of 15
Thread: Help with summerizing
04-02-2018, 02:36 PM #1
Hey everyone. Sorry I’ve been off the grid for a while. Had some family issues that caused me to ghost social media for a bit. But I’m back at it....
So 3 years of paying to have boat winterized I’ve had 3 different ways it has been done. This year the big brass bolt was not taken out if the bottom of v drive but instead I found a long black bolt and cannot figure out where it goes. If I could have someone tell me exactly where it goes that would be awesome! Also I have 2 empty screw holes in the side of the v drive under the orange sticker , see pic below, that I feel like should have something in them. I put a top view for some specific guidance on where the black bolt goes. Can someone check theirs and confirm?
04-02-2018, 03:30 PM #2
04-02-2018, 03:36 PM #3
Awesome thanks so much!!
Any idea of the holes should be open as they are or if they should have thread exposed as they do?
@thewakeboatlife
2016 Moomba Craz
Black/Green
3800# water ballast +500# wakeballast bags
Surf- Doomswell Nubstep/phase5 Wire
Skin- phase5 Danielo Diamond/Hyperlite HiFi
04-02-2018, 03:37 PM #4Senior Member
- May 2016
- West Milwaukee, WI
- 283
Out of curiosity, is that bolt a sacrificial anode rod?
2004 Mobius LS - hooked on footin'
Former tow: 1986 Chaparral 178 XL, 90hp Merc
First tow: 197x Glasspar Citation, 135hp Merc
04-02-2018, 04:26 PM #5
04-04-2018, 04:20 PM #6Senior Member
- Apr 2017
- Atlanta
- 175
Was that the right spot? The bolt under my trans did not look like that one and was much larger. That is an anode on that bolt. I believe there is one on the back of the engine where the raw water is pumped in by the paddlewheel sensor. I'm guessing its that one as it can be used to drain out the cooler. Check you manual for anode locations if that's not it.
2016 Craz
04-04-2018, 05:16 PM #7
I called the dealer and they said it goes under the side of the heat exchanger. I haven’t been at my boat in a couple days so gonna try tonight.
@thewakeboatlife
2016 Moomba Craz-4K in ballast
04-04-2018, 09:51 PM #8
Starboard side. Remove engine divider panel. Look for black metal canister right by your oil filter. It threads in right near the bottom of the sidewall. You will barely be able to see the hole, if at all, so you may have to feel for it. It's awkward and hard to reach. My boat is still in storage, otherwise I'd send you a pic. Let me know if you have any trouble finding it..
Sent from my SM-G930W8 using Tapatalk2016 Craz.
Enzo bags.
04-04-2018, 11:54 PM #9
04-05-2018, 12:51 AM #10
