    Apr 2013
    Default Oil Change - doing it yourself?
    Hey there, tis the season for maintenance... Just checking to see what you guys use to change your oil if you do it yourself?
    I remember seeing something that would pump / suck the oil out since you can't get under to drain. Is this what most use? Any products you recommend?
    I'm looking to start doing a little more work myself if possible - save some $'s (260$ at dealer)- so I can repurpose the savings on surf gear of course...
    2014 Moomba Mojo 2.5
    2013 Moomba LSV (Sold)
    2013 Moomba Outback V (Sold)
    2002 Mastercraft X-5
    Henderson, NV
    pela 6000 oil pump. does a great job but does help to have the oil warm first.
    suck it out, dump new oil in. replace filter and pocket the savings.
    iirc the pela was around $50. it'll also do vdrive/tranny and if you like, your cars/trucks as well.
    Jun 2010
    Benton, LA
    This thing rules, is easy to use, and will pay for itself in no time. I use it on my boat and several other small gas engines.
    https://www.amazon.com/Jabsco-17850-...il+change+pump
    2007 XLV Gravity Games Edition
    340HP CAT/ETX
    ACME 1235 / Fresh Air Exhaust
    I still use one of these simple extractors every time for oil, trans fluid and v-drive oil. Works great.
    https://www.ebay.com/itm/Vacuum-Oil-...-/222594737490
    Sep 2005
    Claytor Lake, VA
    I've been using one of these for 13 years now. Also use it on mowers & golf carts.
    2005 Mobius LSV
    325 EFI
    Jul 2013
    Wisconsin
    Make sure you actually drive the boat around to get the oil nice and hot. I did a late season oil change and didn't run the boat long enough. Needless to say it took a few days to suck it all out
    2008 LSV. 1100 rear sacs and IBS. ACME prop is next
    Ronix One w/ Parks bindings
    Quote Originally Posted by VA LSV View Post
    My wife's Chevy Cruze had an oil plug with a tiny 10 mm head on it. Needless to say the oil lube professionals stripped it out so badly I couldn't get it out. So, for about a year I used the pump to change her oil as well. Then I got smart and waited till the car was good and hot and got on the flange with a vise grip and got it out. Glad to say the replacement plug has an 18 mm head.
