Results 1 to 10 of 60
Thread: Loose Fillings
03-14-2018, 01:11 PM #1
Loose Fillings
OK, lot of sub talk going back and forth last week and I wanna keep it rolling, albeit in a slightly different direction.
2017 bonuses have landed and the Mrs. is letting me keep half of it, LOL!
If you had a comfortable budget (Champagne, not Natty Light)...what would be your ideal Sub/Amp combo?
This would be for a custom ported enclosure, open to consideration of multiple or single subs.
Looking for something that will knock your fillings loose.
....and go!2017 Moomba Craz Surf Edition
03-14-2018, 01:18 PM #2
Do 4 Kicker 10” L7’s & FTW!!!!! Power it with kickers KX2400.1 or get (2) KXM1200.1 if you want a marine amp.
My 4 KM10s pound my sack under the dash. I could only imagine what 4 L7s would do
Sent from my iPhone using Tapatalk2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
03-14-2018, 01:28 PM #3
OK so I admit I get a little lost on impendance when it's a dual voice coil.
the KX2400.1 is 1200 watts RMS x 1 at 4 ohms (2400 watts RMS x 1 at 2 ohms)....the L7's come in dual 4-ohm and dual 2-ohm.
Would (4) L7's in dual 4-ohm (wired in parallel?) present a 2-ohm load to the KX2400.1?2017 Moomba Craz Surf Edition
03-14-2018, 01:30 PM #4
I am super OCD about things matching so I would have to go with a WS SD2 and XXX12.
03-14-2018, 01:32 PM #5
03-14-2018, 01:32 PM #6
XXX, 2 XXX, W7, 2 W6, 2 L7s
Sent from my SM-G928V using Tapatalk2016 Moomba Mojo
2006 Supra 24SSV - Traded
03-14-2018, 01:34 PM #7
03-14-2018, 01:38 PM #8
I'm OCD too so I get it...but I've already mixmatched. Factory Kicker in-boats, Fusion HU, WS Rev10s, etc.
Hypothetically, if your Mojo wasn't already all WS, would you still go SD2 & XXX12? I think it'd be a solid combo and it's on my list of contenders, just curious to your thoughts.2017 Moomba Craz Surf Edition
03-14-2018, 01:40 PM #9
03-14-2018, 01:46 PM #10
If you want to pound and make it easy to install, The Exile Big 12 with their 20.1 or 15.1 amp. My buddy had one in a ported box on his 'Bu, probably the best I have ever heard on a wake boat. Nothing against WetSounds, but my buddy is running the new xxx12, I felt it left a lot to be desired. He is running the proper watts and had a custom built box made by a legit stereo shop. I personally run the Exile 12d off of the javelin amp in a 1.7' rhino lined ported box. I get "that" look from the wife all the time to turn the bass down. This spring, I'll be climbing under the dash to tighten everything up as it has created a few rattles.
2011 Sea-Doo Wake 155
