Results 1 to 10 of 18
Thread: 06 Outback Just Stopped Today!
09-24-2006, 02:22 AM #1Junior Member
- Apr 2006
- 13
I was out on the lake today and my 06 Outback stopped! I had 3/4 of a tank of gas and the motor would turn over, but it would not run! I only have 22 hours on this boat since may. Anyone else have this issue? I am suspecting the fuel pump.
09-24-2006, 06:40 AM #2Senior Member
- Jul 2003
- 340
Need more info. Which motor? Did it die while running or would it not start after you shut it off? Did you notice anything unusual (noises, heat, etc.)? What did you try if anything to get it running?
I'll just mention this because I know someone will, even though it's one of those obvious things. If the boat just stopped running out of the blue, check the kill switch.
09-24-2006, 09:11 AM #3Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Re: 06 Outback Just Stopped Today!
Originally Posted by BaileyAZ
09-24-2006, 09:48 AM #4Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
More technical stuff from Wolf minus
- what is what I wonder
Oh and I should check out that RSS stuff
09-24-2006, 01:16 PM #5Junior Member
- Apr 2006
- 13
The motor is the 310hp w/carb.
I was idling through a no wake cove and when I passed through the no wake area I got on the throttle. The boat got up to plain and then just cut out. We pulled the air filter off the motor and turned it over a couple of times. You could not smell or see any gas in the carb.
09-24-2006, 10:00 PM #6Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Do you see any gas spraying into the carb?
Pull the kill switch and put it back.
Throw a can of water eater in the gas tank
What was the motor temp? Did you suck in a plastic bag in the water intake?
09-24-2006, 11:52 PM #7Senior Member
- Jul 2003
- 340
I suppose it could be the fuel pump, but I doubt it. Pumps will usually show some signs of trouble and do not go out suddenly. If you feel the need to check it, have someone listen to it or wrap their hand around it as you turn the key to the accessory position. You will feel it and hear it spin up as it pressurizes the fuel system. Or take a 12V battery and run some jumper wires to it and see if it spins up.
Once again, the kill switch is the first thing I'd check given your description of what happened.
09-25-2006, 05:49 AM #8Learn all you can today. Tomorrow you may need to know it!
09-25-2006, 07:17 PM #9
try adding gas. Maybe it is your gas gauge?
09-30-2006, 11:08 PM #10Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Originally Posted by smokedog2
Then everyone wanted to be "Wolf", so by the time I would register on a new site, Wolf would be taken by someone who registered and never showed up more than once. So I threw the "-" dash on the end and went from there.
Going boating today!
By cab13367 in forum General ChatReplies: 5Last Post: 04-07-2007, 10:00 AM -
trailer lights stopped working (new car)
By rickmcd59 in forum General ChatReplies: 8Last Post: 07-31-2006, 01:19 AM -
Saw 06 Mob LSV today...Wow
By Livindadream in forum General ChatReplies: 4Last Post: 09-27-2005, 04:17 PM -
Speedometers stopped working on 2005 Mobius LS
By pls4912 in forum Service & RepairReplies: 5Last Post: 07-25-2005, 11:59 AM
