Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 78
  1. #51
    There are no limit switch and the freewheel at the end so no amperage changes. That’s the tough part is one timing the actuator and two turning on a lighted switch that stays on while deployed.
  2. #52
    Aug 2017
    So is it possible to change the timing?
    2019 Supra SL450
  3. #53
    I can set it in one second intervals. They can be changed later but it is complicated.
    If It Was Easy Everybody Would Do It!
  4. #54
    Aug 2017
    Got the template almost worked out. The lower section of the hull is about 6.5 inches, and the nice thing is it's flat, so no spacer needed. Hinges can mount flat to the boat.
    The vertical angle seems good, so I need to take my angle finder to be able to replicate it on the other side.
    I can trim a hair off the top and it will sit flush with the top of the swim step , and I could add maybe 1/2" to the lower rear to get a little more in the water when it's extended.
    Hyperryd, how far in from the edge of the boat did you mount yours?
    2019 Supra SL450
  5. #55
    Aug 2017
    Quote Originally Posted by Hyperryd View Post
    Damn, too bad it couldn't be done in 1/2 second intervals, then figure out a way to make a switch like this have say 2, 2.5, and 3 second positions (or similar, based on the max movement time of the actuator).
    I'm good at dreaming up crap I have no solutions for.
    2019 Supra SL450
  6. #56
    Portland Oregon
    Mount them in 1"
    -Jake
  7. #57
    Aug 2017
    Mount them in 1"
    There's quite a bit of curve in the corners, I'll have to figure out where the flat ends and mount the hinge(s) there.
    2019 Supra SL450
  8. #58
    Portland Oregon
    Yes yours is more complicated than mine. The goal was to match the angle of the hull and be back 1". But I was working with a straight line.
    -Jake
  9. #59
    Aug 2017
    Nothing's ever easy.
    2019 Supra SL450
  10. #60
    Cough,signature,cough,cough
