Results 11 to 20 of 26
  1. #11
    Dec 2016
    Illinois
    Check with either of the Earmark Marine TX stores. The trick is if a shop has done 2-3 in-house and have the gross external dimensions and shape down to a tee. Also depends if they did a mild build that looked completely stock or did they do a more aggressive woofer setup that required some modification and custom facade. This makes it very difficult to do an enclosure thats shipping out to a DIY customer unless they are prepared for some extra fab work once the enclosure is delivered.
    As to the material used. I prefer a high quality ply over MDF. Either way, its all in the preparation and execution. Prep the box right, install it right, it should last.
    What would be a good price for a custom box built to spec and sprayed with truck be liner? Also a custom façade for a nice finished look? I was quoted close to $600
    2016 Moomba Mojo
  2. #12
    Oct 2016
    Tims Ford Lake TN
    Not sure for the finished price of box from a supplier, but to give you ballpark, If I remember correctly, I was $75 to $100 on just materials when I built my own last year: Marine plywood, silicone caulking, fasteners, speaker posts, 2 cans of truck liner spray paint.....
    2016 Mojo Surf
    Raptor 400
    1100 rear bags / 500 IBS / 600 LeadWake
    Exile amps/tower - Kicker in-boat
    FAE
  3. #13
    Arkansas
    Quote Originally Posted by loc82 View Post
    It all comes down to execution. From a reputable shop that knows what they are doing ... that price probably isn't too bad, although it sounds like a lot.
    Is that ported?
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  4. #14
    I was quoted $400 for just the facade from a local shop in Houston.
  5. #15
    Dec 2016
    Illinois
    Is that ported?
    yes it's ported
    2016 Moomba Mojo
  6. #16
    Oct 2013
    whats every one mounting these with would a L bracket work screwed to the box and the floor. if so how thick is the floor so i don't poke the screw through.
    2013 outbackv
  7. #17
    Nov 2016
    Knoxville, TN
    If you're going under helm, I screwed mine to the front wall.
    2011 Sea-Doo Wake 155
  8. #18
    Apr 2018
    Texas
    mine is mounted off the floor
    2015 Mojo
    2005 Yamaha at-230 sold
    2012 Ram 2500 tow rig
  9. #19
    Mine is just sitting on the floor currently. It’s so heavy it really doesn’t move much and when it does I usually just push it back with my feet lol. Not the best set up but I’m having issues deciding how to mount it. I’m not too crafty
  10. #20
    Jan 2018
    I orders rubber amp feet off amazon. Keeps box about 1/2 inch off the floor then screwed to floor with a piece of aluminum angle
