    Oct 2016
    Tims Ford Lake TN
    Default Raptor oil change challenges
    Hey everyone. Tried my oil change this weekend with no luck. Used exact same setup as last year: heated oil up by running off the water hose. I had already snaked the oil pan hose out the transom plug.....shut it down and went to hook up small extractor pump and nothing. No oil drips from gravity drain, nothing sucked up by the pump. The pump could be better, but it did work last year. I have a miti-vac style on order from amazon now. Is it possible to get an air bubble in the hose somewhere that is basically preventing pumping? I know plenty of oil is in there because oil pressure is OK when running the engine. Thanks.
    2016 Mojo Surf
    Raptor 400
    FAE
    Commerce Lake, MI
    Should work. Not need to snake the tube out the bilge drain. I just drain it from inside the boat. You may have kinked the hose when you tried to snake it.
    2017 Moomba Craz
    Apr 2013
    Knoxville TN
    Make sure it's warm.
    Try opening the oil cap where you fill it.
    2018 Supra SL400
    Oct 2016
    Tims Ford Lake TN
    Yeah, it should have been warm. Ran for 10 to 15 minutes at least. I tried opening the oil cap as well on top of the engine. I'm thiking it has to be just a bad extraction pump. My new pump should arrive today and will then give it another shot soon. Just wanted to know if there was an forum experience where a loop or something in the pan hose would cause air-lock for lack of a better term.
    2016 Mojo Surf
    Raptor 400
    FAE
    I had the same issue, I ended up having to get an adapter that threads over the NPT connection on the oil hose to create an air tight seal. Then it drained very well.
    Apr 2018
    Minnesota
    2 things...most likely a kink in the bilge hose (heard a lot about that). Also, open the oil file cap and take out the oil cartridge. I got a lot more oil out after doing those two things.
    2018 Moomba Craz + 500#
    2006 Four Winn H190
    Gull Lake
    Apr 2013
    Knoxville TN
    I think it would be difficult to kink that oil line, but it could happen. Mine is not that flexible.
    I agree with the air-tight seal, remove cap and filter, let it flow.
    I just picked up a new oil filter, so I will be doing this tomorrow before the rain hits TN.
    Good luck.
    2018 Supra SL400
    Oct 2016
    Tims Ford Lake TN
    Thanks for the replies, I hope to give it a try Saturday -- hopefully Friday's rain will move on and I can keep the boat dry on Saturday to do the change and winterize.
    Being lazy here, anyone have a good reference to the NPT cap/coupler that's needed? 1/4 female threaded?
    2016 Mojo Surf
    Raptor 400
    FAE
    Mar 2018
    ALABAMA
    Quote Originally Posted by BigOrange View Post
    https://www.amazon.com/Anderson-Meta...le%2Bpipe&th=1
    2017 Moomba Helix
    Flow 2.0
    AutoWake
    Surf Edition
    WM Rears 1200s
    Fresh Air Exhaust
    Fat Sac 400s (Midship compartments)
    LeadWake bags
    Oct 2016
    Tims Ford Lake TN
    Thanks LA !!!!
    2016 Mojo Surf
    Raptor 400
    FAE
Tags for this Thread
