Results 1 to 10 of 11
    May 2017
    Default Help me with what I'm looking at
    I'm coming from an I/O and I'm not sure what I'm looking at.
    Is this the hose I will install my Strainer Pro in?
    Are these 3 green handles where you shut off water flow to ballast?
    Do I remove this brass bolt to drain water?
    What is this valve for?
    Thanks. I just had the boat winterized and just curious what these are.
    2015 Mojo Surf
    Aug 2011
    Commerce Lake, MI
    Yes that is the water intake hose to the tranny cooler that is black sheathed rubber and on the second to last pic is it's shut of valve to the engine water pickup after that, and on that hose is where you would mount the strainer if you want one. The shiny black hoses are ballast lines and yes that is the plug under the coupling to drain water. Last pic is the paddle wheel speed sensor.
    2017 Moomba Craz
    Sep 2017
    Fairfield, CA
    Quote Originally Posted by SorryCharlie View Post
    Yes, but I highly recommend getting "The Plunger". It looks just like a toilet plunger, but has a hose fitting on the side. It's inexpensive and there's a reason for it: If you add a valve to circulate clean water, you wont be able to assure the impeller is doing it's job. The plunger goes under the boat and forces the boat to intake water like it would in the water. If it doesn't suck up water you have either an impeller or water pump issue.
    Yes.
    It looks like your transmission drain. The drain for the hull should be in front of the motor. "Lowest" point in the hull. When you're refreshing fluids, the most painless way is with a suction pump through the dip stick hole to pull fluid out. If you do this regularly you wont need full flushes.
    Fresh water shut off. The plunger would be placed under this.
    ATTACHED PIC is the transducer or paddle wheel for your speedo.
    Here is the plunger. $20.
    Welcome to the world! Have fun!
    2018 Moomba Max. Well optioned. 1st in CA.
    I used to use the plunger for driveway running - what a PITA... and a mess to boot.
    When the time comes, invest in one of these and never look back. Goes in-line on your fresh water pickup between the hull and the v-drive.
    You could still try the plunger if you are wary but you'll probably find it's not worth it anymore!
    May 2017
    I thought the Strainer Pro enables you to hook up your hose and run the engine in the driveway?
    2015 Mojo Surf
    Dunno - could be. I thought that was more of just an in-line filter than an actual connection for a hose.
    Apr 2013
    Richmond, VA
    sorrycharlie - yes - the indmar strainer pro allows a water hookup and you should install this. I have it and it works great. Don't by a fake a lake they suck to set up and you get all wet which is fine in july but really sucks in November.
    When you run your boat on the stainer pro you will close the water intake valve you have pictured. Remember to reopen this when complete or you will overheat the engine when you run it again.
    2017 Axis T23
    2014 Supra SC350 Sold
    2012 Outback V - Sold
    May 2017
    Quote Originally Posted by JASONZ View Post
    This is the Seastrainer Pro.
    2015 Mojo Surf
    Dec 2015
    north texas
    Seems like I have read that a hose cannot get the engine enough water. Why would something like this even work? Or is it ok at idle to warm oil?
    2017 Supra SA
    Dec 2012
    Ennis, TX
    Quote Originally Posted by russellsmojo View Post
    This will work fine below 1500 rpms. Besides, Indmar designed it! How do you think the dealerships do it in the shop? Fake a lake.
    Shane
    2016 Supra SE
    EXILED
    6 XM9 Tower
    6 Wetsounds XS650 Cabin
    1 EXILE BIG 12 DVC 2000 watt in a ported box
    1 XM 15.4
    XI 1500.1
    2 MX 30.2
    Wetsounds 420 EQ
    EXILE Blue tooth EXBT4
    Blue LEDs
