Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
  1. #41
    Aug 2017
    Guessing you have an air bubble.
    Ideally you would want to raise the bucket high enough to fill the hose and fake a lake plunger.
    A fake a lake typically is fed via water pressure from a water source.
    Assuming you have a open cooling system, if so.......
    Pretty sure you want to hook the garden hose to your fake a lake and run engine until your thermostat opens, then you would put antifreeze through it.
    I personally would pull the water intake hose and gravity feed the antifreeze through it as you run the engine......think of a giant beer bong.
    I got the rain barrel spigot, mounted it on a bucket, and hooked it up to the fake a lake and set the bucket on the swim step. When I put it in neutral and bumped up the rpms a bit, it sucked the antifreeze through like a champ. Sucked up about 5.5 gallons before it started coming out the exhaust.
    Worked great, thanks for the tip!
    2019 Supra SL450
  2. #42
    Has anyone used windshield washer fluid. Freeze point is very low
    Web.
    1997 Outback and stopped looking
  3. #43
    May 2018
    Quote Originally Posted by web View Post
    I don’t recommend alcohol based AF
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
  4. #44
    Jul 2002
    London Ontario Canada
    Alcohol is quite volatile and subject to flashing off in an open environment thus reducing its effectivemess. Plus its not much cheaper than plumbing antifreeze
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
  5. #45
    Apr 2013
    Knoxville TN
    Never heard of that.
    2018 Supra SL400
