Originally Posted by
Jd8ker
How much of the vdrive fluid can you expect to extract? I’m changing the vdrive fluid on my 2020 Moomba Mojo and extracted only .50 quart. Manual says there’s 1.25 in the drive unit.
How small of a tube are you using on the extractor? I had to reduce my line to get around the case to the bottom. I also dropped the trailer jack to force the fluid toward the front. I never got all of it out either but this helps get most out.
2015 Moomba Mojo Surf Edition
4,000lbs
Manual Flow
