Results 1 to 9 of 9
Thread: Prop Wash
    Oct 2016
    Livingston, Texas
    Default Prop Wash
    I need to upgrade my prop from the OEM 14x18 4-blade stainless to either an Acme 1433 or 1939, but then I ran across some posts about props washing out the surf wave on older hulls like mine. Anyone have experience and or advice with this?
    03 Launch 22V
    3) 800lb sacks, Perfect Pass
    Fusion head, JL amps, Wet Sounds Interior/Tower Speakers, 10" Sub
    "Anyone have a stainless steel magnet?"
    Yes, Nettles. Give them a call and tell them what you have and what you want. Definitely get an ACME.
    Apr 2013
    Knoxville TN
    I bought a new prop from Nettles. They talked me out of the model I wanted, and suggested a better size to start with. Also told me if the recommendation did not work, I could trade it back for the other one. As long as the prop was not damaged. The suggestion they made was great.
    Another person driving my boat hit a rock/stump with the new prop. Nettles also fixed the new prop so it looked like new again. Lesson learned about letting other people driving my boat, but not much you can do if you want to wakeboard or surf.
    Nettles - Good people to work with.
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    BTW - I went with a ACME 1433 on my 2007 Supra 22' SSV.
    I was first going to buy the ACME 1617.
    Not too much difference on the two models, but A LOT different from the stock OJ.
    I cannot help on the prop wash for your model boat.
    2018 Supra SL400
    Oct 2016
    Livingston, Texas
    Ok, I'll give them a call. Thanks for the replies.
    Don't be afraid to go with a larger prop.
    I went from 750s in the rear to 1100s and my 1433 (14" dia") was no longer the right prop. Following recommendations here I went with a 2315 (15" dia). Measure the existing clearance w your hull. For me that was fine but I ordered a set of spacers from Boatmate for my trailer.
    2007 LSV
    2315 Acme prop
    Gravity III + 3 Johnsons
    1100s in the rear, IBS upfront
    Stock bags under the seats
    HDPE Surf Platform
    Apr 2013
    Knoxville TN
    Quote Originally Posted by Leebo View Post
    How much weight do you run when surfing?
    2018 Supra SL400
    Call it 3100-3400lbs.
    Surf-side locker has the 1100 pretty close to full-1,000lbs?
    Nonsurf-side at 80%, so 800lbs?
    650 IBS full
    400 Ski locker full
    Old 400 under the surf-side seat, 300lbs?
    Ballast with a heartbeat (people and dogs)?
    When I had 750s in the rear, the 1433 was fine unless I had a big crew.
    2007 LSV
    2315 Acme prop
    HDPE Surf Platform
    Apr 2013
    Knoxville TN
    650 IBS full
    400 Ski locker full
    Thanks. Good point. I’m 2800-300k with usually 4 people. I have not had a chance to run the prop with ballast and 8 people onboard.
    2018 Supra SL400
