Results 1 to 8 of 8
    Aug 2016
    Houston, TX
    Default Recommendations on running speaker wire
    I have a 2011 Launch 22V, and I want to install a Wetsounds zone controller at the helm. Any recommendations on the best way to run the speaker wire from the helm to the head unit, which is in the glove box on the port side of the boat? For those who have done it, is there enough clearance to run up behind the seat around the bow, and use the speaker holes to do a little zip tying as I go? What about navigating around the point of the bow, that's a pretty long stretch with limited access.
    The boat is an hour away, so I can't dig around in at the moment, and I'm just trying to do some planning and I want to order all of the wiring when I order the zone controller.
    Thanks in advance,
    Mark
    What wet sounds zone controller are you installing that involves speaker wire? Do you mean RCA signal cables? Are all your speakers powered by external amps? Who are you order through? Order through a retailer installer that likely knows the answer this this and all the other questions you have. Nothing wrong with asking a retail to have a little skin kn the game, right?
    Contact either of the Earmark Car Audio stores and talk with Odin or Joe.
    Aug 2016
    Houston, TX
    It is RCA signal cables, but I went with a generic "speaker wire" term, so my bad in terms of being a bit loose with terminology. I've talked with Odin, getting it from him, and I need to give him another call, and we spent 1/2 an hour talking, he was immensely helpful. I figured it might make more sense to see if someone on the forum had actually run wiring / cabling through the bow of a similar boat, just in terms of ease of access from under seat, through speaker holes, whatever.
    May 2013
    I went with the Karma SS 6 meter RCA cables. I ran them up and around the tip of my bow like you're thinking. it was a quick and easy run. Mine was on a 2008 XLV.
    www.TraysonsToybox.com
    Nov 2016
    Knoxville, TN
    What Trayson said, around the bow, find another cable maybe and zip tie it up and out of the way. I did that with my new gear, very clean install and fairly easy.
    2011 Sea-Doo Wake 155
    With RCA, I like as short and direct as feasible.
    Aug 2016
    Houston, TX
    Thanks guys, I'll tackle this once it cools off. I'm looking at upper 80s this weekend, so the season's not over, yet!
    Trey and Knox got you.. its around the bow for that boat I do believe.
    2018 Supra SL550
    2017 Supra SE450
