Results 1 to 10 of 11
Thread: Cleaning white upholstery
10-10-2017, 09:17 AM #1Junior Member
- Sep 2017
- 8
My outback has mostly white upholstery which gets a grey tint in spots. It may be mildew. How do you whiten it up?
10-10-2017, 11:26 AM #2
Biokleen Amazing Vinyl & Upholstery cleaner. Available on Amazon, and they have a protectant to use on it afterwards as well.
Sent from my iPad using Tapatalk2017 Moomba Craz
10-10-2017, 11:40 AM #3
this works great 3m marine vinyl cleaner
https://www.amazon.com/dp/B000N9TGTE...a-351740763575A Day at the Lake...Priceless
10-10-2017, 08:07 PM #4
If those store cleaners don't work, try a mixture of vinegar, baking soda, and hydrogen peroxide. I've had good luck on removing mildew on life jackets with this mixture. Google it and pick a ratio.
Gil Hebert
2014 Mojo
10-10-2017, 08:13 PM #5Junior Member
- Aug 2017
- 2
I've used this and it's very inexpensive. Can be found at Dollar Stores. Just need to use a protectant afterwards.
https://www.amazon.com/dp/B004XTTIWA...a-309470210618
10-11-2017, 12:01 AM #6
Yep dollar store awsome and a soft drush to get in the texture of the viynl. Then use a non slick protectant to bring back the shine. Will look like new.
10-11-2017, 06:00 AM #7
Maybe try jomax and bleach mixture as prescribed on the jomax bottle... I would try a small spot first to see, I have used it with success
2011 Sea-Doo Wake 155
10-11-2017, 06:32 AM #8
Totally Awesome is a great cleaner, but it has to be diluted if using on vinyl. It is very concentrated.
Sent from my iPhone using Tapatalk2017 Moomba Craz
10-11-2017, 11:04 AM #9
Once you clean it be sure to put something on to protect it like 303 or other. Need to keep the vinyl from drying out.
2007 XLV Gravity Games
1,100 in each rear locker
1,180 in front
Fresh Air Exhaust
SuckG8
Bunch of other crap
11-28-2017, 10:09 PM #10
I just tried cleaning some mold/mildew off of my jetski seats with Awesome and it didn't do a thing. I haven't tried any of the other stuff mentioned, but once I used the baking soda and hydrogen hydroxide mixture it removed every ounce of mildew. I just eyeballed amounts until I had a thick sludge that I could spread on the seat and let it sit overnight. In the AM the sludge had become a solid that I lifted off. I rinsed the seat and it looked good as new. I will find something with mildew on it to get some pictures of using this process because it is just magic.
Do not throw the solid mixture on your driveway, apparently it is not water soluble.Gil Hebert
2014 Mojo
