Results 1 to 8 of 8
    Apr 2015
    Default On Board Charger
    Anyone see any issue with leaving the on-board charger plugged in all of the time? I seem to have a small parasitic draw that has been killing my batteries. I almost always turn the switch to the off position but it still seems like if it is more than a couple weeks before I use the boat again I will come back to weak batteries.
    I think the easy answer is just to make plugging in the charger part of my routine every time I cover the boat but I just want to make sure there are no ill effects of leaving it plugged in all of the time. For reference my boat is a 2015 with the stock dual battery setup and on board charger.
    2015 Mojo with autoflow
    Sep 2017
    Fairfield, CA
    Quote Originally Posted by cpropes2005 View Post
    I don't wanna sound like a jerk, cuz asking never hurts, but I'd say that's what it's there for. I'd be more concerned about the parasitic draw than the on-board charger, personally.
    If I'm wrong, please correct me. Good luck man!
    2018 Moomba Max. Well optioned. 1st in CA.
    Jun 2010
    Benton, LA
    It is designed to be left on.
    2007 XLV Gravity Games Edition
    340HP CAT/ETX
    ACME 1235 / Fresh Air Exhaust
    1180 Front, 1100s Rear, 400 under Surf Side Seat, Homemade Suckgate, Custom Surf Platform
    Slingshot Hooke, Doomswell Neo, Phase 5 Hammerhead, Parker Surfcraft Phantom
    Apr 2015
    Haha, no worries. Reading it back to myself it does sound like kind of a dumb question. This is the first on board charger I have ever had so I guess I am just used to my old mentality of only using a battery charger if a battery is low.
    Related dumb question. Does the position of the battery switch have any impact when using the charger? I would suspect that they have the charger wired independent of the switch but I have never actually traced the wires to find out.
    Oct 2010
    Lake Wylie NC Area
    If the main battery switch is off and the both batteries are low, you have big problem thats going to be fairly simple to find. Not many thinks should be wired direct to the battery and none should be wired to both batteries.
    So, IMO, fix the draw or bad battery issue. Why? because if it is a battery issue, you will end up with bigger issues with a charger trying to charge a bad battery. 2nd, even a small load can keep the charger working nonstop, which its not indented to. Not good for a battery and not good for the charger.
    Yes, a marine on-board smart charger is intended to remain plugged in.
    Yes, the switch position matters. need to be off.
    Jul 2015
    Here's a question. Is there a way that I can wire my onboard charger, to my battery pack (2 batteries), on my hoist? They are kept charged by a solar panel. Old thread, but maybe someone will see it....
    Mar 2003
    s.e. washington state
    Options: Get a 12 volt inverter to provide 120VAC to the charger , tie into the hoist battery pack and have the panel maintain all 4 batteries or have a switch to have the solar panel maintain the hoist batteries or boat batteries or perhaps all of the batteries. The inverter will have some power loss and something to maintain whereas a direct 12 volt connection for your solar panel would be simple but I would recommend a diode in line to ensure there will be no drainage of your boat batteries.
    1998 Mobius
    310 HP PCM
    SOLD
    Oct 2010
    Lake Wylie NC Area
    I would suggest a 2 bank charger for a 2 bank system. Otherwise, you would have to keep the battery switch on, which is less then ideal. The other thing is taking into account the potential draw of the charger v's you solar's output.
