Results 11 to 20 of 22
  1. #11
    May 2016
    Fargo, ND
    Quote Originally Posted by mattsask View Post
    Adding 3 more pumps is definitely on my winter project list. Waiting 14 minutes for the Enzo's to fill gets old fast
    I am very interested in this mod too. Curious if there is enough available power for the extra 33 total amps. Have you started any research on the project?
    2016 Mojo
  2. #12
    Jun 2017
    Quote Originally Posted by evoimport6 View Post
    I tested out the fi23 back at wakefest. It is an awesome boat. However they still use pnp systems to fill bags. They use 4900 labs of ballast but only the hard tanks get quick fill. Also the fi is going to be expensive. The boat I tested was msrp at 123k. It is a huge disappointment when it came to money. Boats surfwake was monsterous though.
    The way I understood it has 4K of ramfill and two 400lb bags.
    '19 Moomba Max
  3. #13
    May 2013
    Vancouver WA
    Ramfill is cool and all. but I remember a morning on my buddy's centurion. The smaller lake was pure glass and I couldn't wait to wakeboard on it. Oh, but we had to fill the ramfill tanks. So we had to motor for like 90 seconds and destroy all my glass so I could have nice ballast to wakeboard on.
    www.TraysonsToybox.com
  4. #14
    Jan 2010
    North Texas
    centurion has ramfill.
    mb has gate valves.
    has shown up on a couple of boats. same basic concept just different ways to reach the same result.
    kinda surprised the new supra that I heard has hard tanks didn't install something like this. down side tho is if the gates stick open, your day is done. I have seen an mb have to load on a trailer as one of the gates stuck open and wouldn't drain. fun to watch a half-ballasted boat try to leave the water.
    The SL has bags under the floor for the new subfloor ballast.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
  5. #15
    Jan 2010
    North Texas
    mb has gate valves.
  6. #16
    Sep 2010
    Lake wallenpaupack PA
    Quote Originally Posted by PuraVida View Post
    I am toying with this as well.. looking to add 3 king pumps... You would need to add a series of relays to active the pump in both directions... I am assuming a second battery would probably be smart.. There wouldnt be a drain on the main system as the relays would tell the pumps to start working off of the second battery.. There is a thread on hear that talks about relay wiring... You would need 2 relays for each pump one for fill and one for empty..... I have a '17 craz and there is plenty of room behind the storage walls to add the pumps.. the only question i would have is for the center tank and bow sac I guess you would have to hook the pump directly to the bow sac as the center hard tank doesnt have a second fill location... I would imagine the center and bow sac would have different fill times so that could cause one of the pumps to run while empty as the other is still working(assuming they are both wired together)
  7. #17
    Aug 2008
    Hilliard, Ohio
    Quote Originally Posted by lsvboombox View Post
    Don't forget to add some holes to the bottom of the boat as 1 will not feed 6 pumps.
  8. #18
    Sep 2010
    Quote Originally Posted by patrick232 View Post
    that would be the next item to tackle, but is the factory only using 1 thru hull to feed 3 pumps currently?
  9. #19
    May 2016
    Fargo, ND
    I have 3 holes, one for each pump in a 16 mojo. Curious if you could run 2 pumps per hole without a major loss in flow. Anyone know how the 18s run the 6 pump system?
    2016 Mojo
  10. #20
    Nov 2014
    I seem to remember drew tinker making a comment on the Facebook page about this particular question. He basically said that through their testing, the 6 pumps will draw as much water as they need through the same three holes.
    As for the IBS/ center tank. I was thinking I'd just run the center tank on the timed switch and then add a switch and pump dedicated to the IBS, then add one of those wakemakers inline ballast timers.
    Sent from my SM-G930W8 using Tapatalk
    2016 Craz.
    Enzo bags.
