Results 1 to 8 of 8
08-31-2017, 07:47 AM #1Junior Member
- Jun 2016
- 5
Rear ballast bag won't stay clipped
Hi! I have a 2015 Moomba Mojo Surf Edition. The port side rear ballast bag came unclipped when it got really full one time and now it comes unclipped every time we fill it. Is there anything I can do to keep it clipped? I wasn't sure if there was originally some type of glue or something that helped it stay clipped.
Thanks!
Christine
2015 Moomba Mojo2015 Mojo
08-31-2017, 07:59 AM #2
Do you mean the hose pops off with the red clip or the fitting comes out of the bag
08-31-2017, 08:10 AM #3
If the fitting with the red clip won't stay on, then the fingers on the connection may be damaged and will need to be replaced. You need to inspect the two fittings to see.
Sent from my iPad using Tapatalk2017 Moomba Craz
08-31-2017, 11:41 AM #4Junior Member
- Jun 2016
- 5
The fitting with the clip pops off. It doesn't look to be damaged. It stays on for a while. I'm not even sure if the bag is placed properly in the compartment. We had to move it around to get the clip back on, so I'm not sure if it is even in the right place.
2015 Mojo
08-31-2017, 02:21 PM #5
Remove the tether from the rear fill hose and locate it closer to the elbow so,it has more give, and ensure you really have the connection pushed down all the way before you slide the red locating collar down in place.
08-31-2017, 02:57 PM #6Junior Member
- Jun 2016
- 5
Thank you. I will try that.
2015 Mojo
08-31-2017, 04:13 PM #7
I thought I read on wake makers you can glue them om, but there are disadvantages to that if you ever want to change the fittings out.
2018 Supra SL400
08-31-2017, 04:23 PM #8
You can glue the fittings into the bags, but I wouldn't ever glue the hose fitting onto the bag fitting.
