Results 1 to 2 of 2
    May 2013
    Vancouver WA
    Default Oil Pressure Gauge reading
    So we were motoring out to our ride spot last night. My oil pressure is pretty typical of what most others here have: around 40 at idle and 50 or 60 under surfing load.
    We were motoring over some medium chop and the needle just DROPPED all the way to zero and was bouncing around the bottom of the reading. Then it came back to normal. I turned off the engine. Restarted and it was normal pressure at idle. I gently increased speed and it behaved normal. Then maybe a minute later it did it again. This time I checked the oil level and it was totally fine (3/4 of the way between the full and add lines). I've had oil pressure problems before (low oil, check engine light, limp mode) but that was because I was low on oil).
    Any thoughts on this? Is my sender going bad? Gauge going bad? Or is there an intermittent legit problem I should be concerned about?
    www.TraysonsToybox.com
    It could be a loose ground at your gauge or loose connection at your sending unit.
    Normally low oil pressure is all the time or mor consistent at low speed, high speed things like that.
    [COLOR="#696969"]
