Thread: Trans Clunk
    Jul 2009
    Syracuse Utah
    Default Trans Clunk
    Hey guys
    When I put my 2013 LSV in gear, it makes a clunk sound as it goes in to forward drive. Is that normal? I haven't been on other boats to really compare that sort of think.
    2013 Moomba LSV
    Aug 2011
    Commerce Lake, MI
    What does your trans oil and fluid look like? When were they last changed? There are two separate oil systems. Gear oil for the gears and transmission fluid for the clutch - don't mix them up if you do change them!
    2017 Moomba Craz
    Jul 2009
    Syracuse Utah
    Quote Originally Posted by Stazi View Post
    My transmission fluid looks great. My vdrive oil looks great.
    Where would I find the gear oil you mentioned?
    Going back to my original question. Does your boat give a clunk when going into gear?
    2013 Moomba LSV
    May 2013
    Vancouver WA
    see my post in your other thread. check your coupler bolts on the output shaft to the propeller shaft. I bet they're loose.
    www.TraysonsToybox.com
    There will be an engagement clunk but it's a very solid low type of noise
    Deff check coupler, drive bolts, also check engine mounts, trans mount bolts
    Maybe pull the V drive cover off watch and listen as someone puts it in gear
    [COLOR="#696969"]
